[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Isuzi MU on ebay
Do all Mu's come with the air filter/intake on the nearside? Thinking it might be worth looking out for Mu's at scrappers for a safari snorkel conversion for the 2.8's, which means the pipe work will be on the nearside.
