Head Gasket
Head Gasket by steve8895 on Fri Sep 25, 2009 7:50 am
Hi All,
Quick question if anyone can help ?
I am in the middle of renewing my head gasket and noticed that the gasket I removed has small holes ( 5mm ) for the water flow. Does this not restrict flow of water across the engine and is it supposed to.
I found it strange as the shape on the head and cylinder is is more of a slot ?
Any advice would be great
thanks
Steve
steve8895
Re: Head Gasket by andysd1 on Fri Sep 25, 2009 8:39 am
the gasket should sit flush with all the holes on the block, have you got the new one yet, no over laping of the holes,
Re: Head Gasket by 4x4 bobby on Fri Sep 25, 2009 8:56 am
There are a few types of gasket as i found and you must get the correct one I had to use chassis number to get the right one.
Good luck mate.
Re: Head Gasket by steve8895 on Fri Sep 25, 2009 10:52 am
Hi Andy and anyone else out there
I have attached pictures of head and cylinder,
I have not bought the gasket kit yet but have been quoted £70 incl VAT. This includes new bolts and is from a small company round the corner from were I work. They have been recommended to me and have been there donkeys. They also pressure test and skim heads. i also need a couple of new exhaust manifold studs as previous owner had it repaired and they did a catastrophic repair that I did not know about when I bought the car 3 months ago and they will not give any warranty.Let me know what you think. underneath the gasket on the cylinder picture the slot is one long slot on each side of bore.
Cheers Steve
steve8895
Re: Head Gasket by 4x4 bobby on Fri Sep 25, 2009 11:08 am
You could do with having the head skimed if its not been done allready.
Re: Head Gasket by steve8895 on Fri Sep 25, 2009 12:36 pm
Hi again,
head was skimmed previously and do not think it will cope with another so hoping it is ok
Steve
steve8895
Re: Head Gasket by BUMPTJ on Fri Sep 25, 2009 1:10 pm
Hi mate, £70inc vat for the head set and bolts is a fairly decent price but you should be able to get them down to £60. There is only 1 set listed on that year and engine, and comparing the pics of the one we stock to the one on the car they look the same. The reason for the difference in size on the holes in the head to the gasket is that if the holes were the same size then the water circulation aRound the engine would be too slow, so by restricting the flow with the gasket the water flow is increased. Italso stops cavitation at the water pump
BUMPTJ
The Parts Man
Re: Head Gasket by steve8895 on Fri Sep 25, 2009 2:09 pm
Cheers for info to everyone,
Really appreciate all your advice.
Steve
steve8895
Re: Head Gasket by fogman on Fri Sep 25, 2009 2:41 pm
hi mate the gasket looks exactly the same as that on mine, you said that the head had been skimmed when the gasket was changed quite recently by the previous owner so judging by their bodge up of the manifold studs wouldnt it be prudent to get the local company who are going to supply the gasket set to check the head before reassembley ? if your heads shot then it would be better to know at this stage because it will only go again ! ! !
Re: Head Gasket by Spike on Fri Sep 25, 2009 8:43 pm
I would never take an alloy head off an engine without having it checked and skimmed prior to refitting... Any decent mechanic would advise that........
Spike
Modifications: 2" + Landrover Springs on rear.. 2" lift on Front.
235/75 x 15" Recip Tyres all round 80% mud, 20% Road
Light bar on roof, 4 front facing spots, Wired to come on via full beam via switch 2 rear facing wired through reversing lights, via a switch.
Re: Head Gasket by jcv1968 on Fri Sep 25, 2009 9:39 pm
I always make sure the mating surfaces are absolutely spotless before fitting new gaskets. If you use a metal scaper you must be very carefull not to dig the aluminium. There are now plasticscrapers available that do an ok job but takes longer than traditional methods but doesnt mark the metal. I have a 500mm engineers steel rule that I use to check for any distortion, Its not fool proof, but is a cheep method of checking. Does the gasket kit come with all the other gaskets? If not it can get quite expensive by the time you've got all the others. I paid £65 for the last one I did and that came with everthing. Good luck anyway.
My other Frontera is a Frontera. My Corsa is a baby Frontera.
jcv1968
Vehicle Name: Freddy
Modifications: Refitted a propper vauxhall radio!
Rebuilt engine, fast road cams, new injectors, Lamda sensor, Crank sensor.
Re: Head Gasket by steve8895 on Sat Sep 26, 2009 9:58 am
Hi Alll,
i am having the head pressure tested monday and hopefully as mentioned it does not need skimming. And all exhaust studs replaced that need to be.
they are providing me with full gasket kit so should be able to do a proper job after these cowboys.
cheers for advice everyone
steve8895
Re: Head Gasket by fogman on Sat Sep 26, 2009 11:21 am
you will find that theres loads of air that is reluctant to leave the so called "self bleeding system" make sure your heaters in the hot position when refilling & we found that gently releasing the heater matrix pipe allowed the air to escape but it did take quite a long time , also make sure you get the correct antifreeze/coolant, red coloured, hope all goes well :wink:
might help - viewtopic.php?f=2&t=92
anyone know how much the system takes ? its handy to know how much has gone in :wink: i cant remember & i know A friend posted it for me but im buggered if i can find it :(
Re: Head Gasket by steve8895 on Sat Sep 26, 2009 3:32 pm
Cheers for info Fogman,
let you know how i get on
Steve
steve8895
Users browsing this forum: No registered users and 76 guests
