Frontera Technical Support • View topic - trailer suspension lift spacers*done*
trailer suspension lift spacers*done* by Krusher on Mon Aug 10, 2009 3:53 pm
I'm not sure anyone will be able to help me sort this but here goes.
I need to lift the suspension on my camping trailer to match the 2" lift of the Fronty. The spacers are simple enough
to make if you got the gear to do it, which I dont :cry: They will look something like this(please excuse the poor diagram)
Can anybody help me with this or recommend somewhere in East Kent where I could get them made?
Cheers for any help.
Re: trailer suspension lift spacers by weave67 on Mon Aug 10, 2009 3:55 pm
were does that fit mate :?:
Re: trailer suspension lift spacers by Krusher on Mon Aug 10, 2009 3:59 pm
It will fit between the chassis of the trailer and the axle which has a flat mounting bracket. Trailer suspension is inside
the axle itself. Sorry mate my descriptions are not up to much today are they?
Maybe these will help?
Re: trailer suspension lift spacers by gregster on Mon Aug 10, 2009 6:29 pm
Hiya mate...just use 4 body lift pucks and bolts...will do the jobbie just fine...
Speak to the yakatar...rumour has it, when he is constipated, he poos these thing out by the dozen!!
Hope this helps matey..
Gregster
Re: trailer suspension lift spacers by Sir-Doris on Mon Aug 10, 2009 8:12 pm
2" box section and a drill should do it.
Re: trailer suspension lift spacers by yaki on Mon Aug 10, 2009 9:05 pm
Re: trailer suspension lift spacers by troy on Sat Aug 15, 2009 1:21 pm
I had the same problem towing my trailer tent with the back end scrapping the road. Solved the problem by fitting a drop plate on the tow ball only a couple of quid from towsure the drop plates range from 2"drop to a 6" drop. just disconect the plate when not towing .
troy
Re: trailer suspension lift spacers by Krusher on Tue Aug 18, 2009 6:18 pm
I finished the trailer and it now doesn't sit so low at the back. Just used abit of 2" box section as suggested, painted
with hammerite and Bobs your uncle. I'm quite pleased with the result :dance: :dance:
Re: trailer suspension lift spacers*done* by gregster on Tue Aug 18, 2009 7:42 pm
Looks good matey...certainly done the trick... :wink:
Job well done... 8) 8)
Looking good, a small ladder rack on the front will help you see it when reversing.
Re: trailer suspension lift spacers*done* by Krusher on Tue Aug 18, 2009 8:56 pm
Re: trailer suspension lift spacers*done* by gregster on Tue Aug 18, 2009 9:07 pm
Re: trailer suspension lift spacers*done* by yaki on Tue Aug 18, 2009 11:12 pm
