M-day (M.O.T)
M-day (M.O.T) by drinksoptional on Tue Aug 04, 2009 10:28 am
Well i bit the bullet and phoned my local MOT station this morning and lucky for me they doing MOT`s till 7.pm there open till 8pm which could be handy. so i have a spot at 2:30pm today. The fronty a sorry state both passenger side tyres completly flat, fuels is on fumes and its not moved since start of july. I need to get my butt in gear get it tidy fueled and tyre inflated. Hopefully this time they will not brake my steering like last time on my escort. i do not expect it to pass as there a couple of thing needing done i just hope it not a list i got a few ££ set aside so will be on the net/phone ordering bits
Re: M-day (M.O.T) by john (smifffy) on Tue Aug 04, 2009 10:43 am
best of luck with it :drink:
Re: M-day (M.O.T) by drinksoptional on Tue Aug 04, 2009 1:29 pm
Just because it should does not mean it wont,
what am i on about some out there will know.
Ever said the words should only take.. well it didnt 20minutes to remove spot lights cause one cracked. Then i used the plug in pump for the tyre i thought i would inflate the tyres enough to get to the petrol station and warm the engine and what happens The car urinated on me a friggin wee pin hole in the bottom of the radiator . I had to losen the expansion tank to relief the pressure think the cooling fan decided not to work. She said how long you be " I said not too long only walk round to petrol station come back inflate the tyre`s, remove the spots and warm the engine then have a cuppa before MOT.. It is too much to ask for sods law to f.o for a bit. nothing i can do now.
Re: M-day (M.O.T) by Roo on Tue Aug 04, 2009 2:26 pm
Hi Drinks
Hope all goes well for your Car today :D Image for ya
Let us know how you get on please :)
Cheers now and good luck :dance:
Re: M-day (M.O.T) by crabman on Tue Aug 04, 2009 3:03 pm
Good luck .
''Too bad it didn't thunder when you said that. That would have been cool. Like you're an evil genius or something.''
My wagon viewtopic.php?f=46&t=23335
Comments on my wagon viewtopic.php?f=32&t=27552
crabman
Vehicle Name: Lars , you need not fear me .
Modifications: General Grabber AT2 255 65 16 AT tyres fitted to 16x8 black modular wheels , standard Tokico shocks and replacement springs(+20%) , front adjusted to match, Sidesteps removed , rear light guards removed , spare wheel holder removed , bullbar removed , badges and stickers removed .
Re: M-day (M.O.T) by domino on Tue Aug 04, 2009 3:05 pm
Wonder how it's going..... :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: M-day (M.O.T) by drinksoptional on Tue Aug 04, 2009 4:07 pm
phoned them at 4pm told another half hour, when i dropped it they said next in line if it comes back dirty
Re: M-day (M.O.T) by drinksoptional on Tue Aug 04, 2009 5:08 pm
VERDICT:
o/s stop lamp not working
o/s headlamp aim too high
nearside (no beam pattern) headlamp aimed so that it dazzles other road users
rear fuel pipe leaking
o/s front (two pipes) brake pipe excessively corroded
o/s rear (sill) seat belt anchorage corroded
There was advisories which i thought i would get failed on:
o/s brake pipe slight corroded
n/s front brake pipe slight corroded
n/s rear shock absober has misting of oil
rear brake pads wearing thin
n/s and o/s front wheel bearing slight play
All i can say is that was a good result. he said he was been as leanent as possible
i cannot complain this time.I will do the easy stuff get my dad to weld as i cannot nor do i own a welder and he has brake pipe making tool
Users browsing this forum: No registered users and 69 guests
