Gearbox oil for chevybravafing
Gearbox oil for chevybravafing by gregster on Mon Jul 20, 2009 8:07 pm
Hiya...
Anyone know what oil is should put in the tf box and gearbox of the chevybravafing...it is 2.8td isuzu really! 8)
Also is the tf and gearbox oiled together on these or are they filled seperate.
Muchos Grassyarse....(thankyou...or wot you get if you slip over on a lawn!) :oh yer:
Da Gregster
Re: Gearbox oil for chevybravafing by alex on Mon Jul 20, 2009 8:18 pm
Mineral 15-40 engine oil in both. Same as the enigine. Dont use any synthetic. I used Molly for gearbox, but as Drifty pointed out, if your using engine oil in a box, use engine molly in there too.
Re: Gearbox oil for chevybravafing by Drift on Mon Jul 20, 2009 8:23 pm
Yup and they are separate 8)
Re: Gearbox oil for chevybravafing by gregster on Mon Jul 20, 2009 8:52 pm
Cheers guys...thought I should at least stuff some more in the TF box as its leaked a bit when I have had the prop out a few times...
Re: Gearbox oil for chevybravafing by Sir-Doris on Tue Jul 21, 2009 12:25 am
Drain plugs are 24mm as are the fill plugs I think. Should be fairly obvious, both drains low down, and fill plugs a shade over halfway on each side.
Re: Gearbox oil for chevybravafing by Drift on Tue Jul 21, 2009 7:15 am
And remember to open the filler plugs before the drain plugs :wink:
Users browsing this forum: No registered users and 70 guests
