Frontera Technical Support • View topic - out of fuel
out of fuel
out of fuel by simo_d on Fri Jul 17, 2009 2:22 pm
Ran out of fuel put about 11 quids worth in still won't start
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
Vehicle Name: Elizabeth
Modifications: 2"lift,
buckshot mudders
air horn
yellow bash plates :)
internal snorkel
light guards all around
Re: out of fuel by Road Hog on Fri Jul 17, 2009 2:26 pm
Probably sucked crud into the fuel pump pick up pipe filter & blocked it :wink:
Re: out of fuel by simo_d on Fri Jul 17, 2009 2:37 pm
Oh darn
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
buckshot mudders
air horn
internal snorkel
Re: out of fuel by Road Hog on Fri Jul 17, 2009 2:42 pm
Try disconnecting the fuel line under the bonnet & blowing down it,if it is the problem & you are lucky it may well clear it :wink:
Re: out of fuel by john (smifffy) on Fri Jul 17, 2009 2:44 pm
take the fuel pipe off the back of the fuelfilter under the chassis
and blow back down pipe to the tank then put pipe back and try again :D
hopefully it will clear any crud from microfilter in tank :D
Re: out of fuel by Road Hog on Fri Jul 17, 2009 2:53 pm
Re: out of fuel by Rich on Fri Jul 17, 2009 4:17 pm
i had the same problem with mine when i ran out of petrol the way i got it running was to remove the fuel pipe from the injector rail and crank the engine until petrol began spitting out reconnected the pipe and away it went it was like it had air locked
Re: out of fuel by andysd1 on Fri Jul 17, 2009 4:48 pm
i depressed the valve on the fuel rail, and nothing came out, no pressure at all,
this is how he went home
Re: out of fuel by weave67 on Fri Jul 17, 2009 5:09 pm
thats not good i hope you get it sorted,incase you dont put me down for the tyres :roll:
Re: out of fuel by simo_d on Fri Jul 17, 2009 5:49 pm
:shock: where about is the fuel pump on 2.0i petrol
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
buckshot mudders
air horn
internal snorkel
Re: out of fuel by john (smifffy) on Fri Jul 17, 2009 5:50 pm
Re: out of fuel by andysd1 on Fri Jul 17, 2009 6:01 pm
have you taken the pipe of and blown down it
Re: out of fuel by simo_d on Fri Jul 17, 2009 6:08 pm
I couldn't blow through
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
buckshot mudders
air horn
internal snorkel
Re: out of fuel by weave67 on Fri Jul 17, 2009 6:17 pm
how about fuel relay :?: :?:
Re: out of fuel by jontera on Fri Jul 17, 2009 6:22 pm
I just know that it's going to be a cheap repair.
I'm betting on it having picked up muck off the bottom of the tank. be that micro filter thing in the tank.
gives you a reason to drop the tank and give that guard a good cleaning and a lick of paint.
always sad sight to see a Fronty on recovery but at least we know that yours will be back soon.
Re: out of fuel by Krusher on Fri Jul 17, 2009 6:50 pm
Run out of FUEL :oh yer: :oh yer: :oh yer: :oh yer: :lol:
Re: out of fuel by simo_d on Fri Jul 17, 2009 7:24 pm
Going to take fuel tank off tomorrow is there anything I should be aware of ( never done it before)
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
buckshot mudders
air horn
internal snorkel
Re: out of fuel by Krusher on Fri Jul 17, 2009 7:37 pm
Yeah, Its got 11 quids worth of juice in it! :lol:
Re: out of fuel by Road Hog on Fri Jul 17, 2009 7:42 pm
:way off topic:
Re: out of fuel by andysd1 on Fri Jul 17, 2009 8:07 pm
you have been a pain in the neck all day to me, so it comes as no surprise when i say if you want a hand give me a shout, I'm up early tomorrow
