Frontera Technical Support • View topic - 2" lift easy or not???
2" lift easy or not??? by vyron on Wed Jul 15, 2009 4:12 pm
how easy is it to do. at the front end do i have to drop the bottom ball joints?
vyron
Modifications: c-trax mt's front n rear.
steel wheels fitted.
mud flaps removed....
wheel carrier removed.
Re: 2" lift easy or not??? by andysd1 on Wed Jul 15, 2009 4:19 pm
you dont have to touch the ball joints, but for a bit more drop, you can flip the top ball joint, understanding the word flip, just means taking it from its location and placing it under the top wish bone, and the wind the torsion bars up 8 turns, clock wise, if you are using the 2" spaces for the back, it will take about an hour, ish.
Re: 2" lift easy or not??? by weave67 on Wed Jul 15, 2009 5:15 pm
hmmmm i got some 2" spacers in my shed (just by chance :wink: )
Re: 2" lift easy or not??? by vyron on Wed Jul 15, 2009 5:29 pm
i. i know this to be true weaver just waiting to pay day and be having these from you :D :D :D
since this has not been touch since it came off the factory floor its going to damn tight is it not?
vyron
Re: 2" lift easy or not??? by weave67 on Wed Jul 15, 2009 5:30 pm
you will be fine mate ive seen em fitted in about 20 mins easy peasy :wink:
Re: 2" lift easy or not??? by vyron on Wed Jul 15, 2009 5:36 pm
i hope so :D pick ups almost finished.
get some new muddy's lift. and we will be done.
bucketed down this morn. and its still dry inside so there's some luck on my side. :D :4x4: :D
vyron
Re: 2" lift easy or not??? by Krusher on Wed Jul 15, 2009 7:38 pm
Hi Bud
2" lift was easy with spacers from Alex, was just looking through some of my old posts for the step by step pics
from when we did mine but cannot for life of me find them. :oh yer:
Re: 2" lift easy or not??? by ricky-tk on Wed Jul 15, 2009 11:01 pm
Frontera 2.5 TDS
BMW F 650 Enduro
G0LZX/G1VWL
http://www.qrz.com/db/g0lzx
ricky-tk
Re: 2" lift easy or not??? by ricky-tk on Wed Jul 15, 2009 11:02 pm
Frontera 2.5 TDS
BMW F 650 Enduro
G0LZX/G1VWL
ricky-tk
Re: 2" lift easy or not??? by Drift on Wed Jul 15, 2009 11:15 pm
Word of warning, be prepared to replace the ball joints as you will most likely wreck them splitting them to flip :wink:
The will wear out soon anyhow if they are old so may as well be replaced
Re: 2" lift easy or not??? by weave67 on Thu Jul 16, 2009 5:39 am
Re: 2" lift easy or not??? by ricky-tk on Thu Jul 16, 2009 11:42 am
:party: cheers dave :-)
Frontera 2.5 TDS
BMW F 650 Enduro
G0LZX/G1VWL
ricky-tk
Re: 2" lift easy or not??? by weave67 on Thu Jul 16, 2009 2:46 pm
starting there journey tomorrow mate :wink:
Re: 2" lift easy or not??? by huggy on Fri Jul 17, 2009 2:01 am
wouldnt mind a set of spacers myself but would this throw the back axel out of line? and would the load compensation valve work as it should?
huggy
Re: 2" lift easy or not??? by weave67 on Fri Jul 17, 2009 5:28 am
with 2"you dont have to touch anything :wink:
Re: 2" lift easy or not??? by huggy on Fri Jul 17, 2009 7:22 am
cool 8) do you have any left and if so how much?
huggy
Re: 2" lift easy or not??? by fogman on Fri Jul 17, 2009 9:25 pm
Re: 2" lift easy or not??? by Krusher on Fri Jul 17, 2009 9:55 pm
Re: 2" lift easy or not??? by fogman on Fri Jul 17, 2009 9:57 pm
thanks k :wink:
can i ask where you brought the spacers ? i know that id probably need a different size or whatever but i aint got a clue where i would go to get some !
also did you just wind up the torsion bar at the front ? and that was job done ?
Re: 2" lift easy or not??? by Krusher on Fri Jul 17, 2009 10:12 pm
I got mine from Alex whilst at Bala. He fabricated them for me and others to there spec. You could try a PM to him to see if there is any more and then the torsion bars wound up to match the 2" spacers. :wink:
