Frontera Technical Support • View topic - a rumbling i will go...
a rumbling i will go... by Dave_RAYNET on Mon Jul 13, 2009 4:39 pm
I know this is a technical issue but not sure where its coming from so unable to post in relelvent section....
My sport has a rumble from the rear offside.
The best way to discribe it is a cross between a knocking cv joint on a "normal" car and one of those rolling things they walk along with to flatten tarmac.
Its louder under power, quieter when coasting but still audible. IT has no effect on driving the truck and causes no problems.
Any ideas?
Bearing? Drive shaft? diff? Trapped squirrel?
I had a look, but to my untrained eye nothing looked out of place....
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: a rumbling i will go... by weave67 on Mon Jul 13, 2009 4:42 pm
rear bearing maybe :wink:
Re: a rumbling i will go... by Dave_RAYNET on Mon Jul 13, 2009 4:50 pm
Dave_RAYNET
Re: a rumbling i will go... by weave67 on Mon Jul 13, 2009 4:53 pm
best way is to jack it up remove the wheel and drum and feel for play in the half shaft itself :wink: if it is the bearing its not that bad a job with the bearinator :wink:
Re: a rumbling i will go... by Dave_RAYNET on Mon Jul 13, 2009 4:59 pm
Dave_RAYNET
Re: a rumbling i will go... by Sir-Doris on Mon Jul 13, 2009 6:31 pm
Remove roadwheel.
Loosen the handbrake shoes using the adjusters on the back of the drum. This loosens the shoes so they dont catch on the lip inside the drum as the drum will have worn somewhat.
Tapping the back of the drum with a mallet or hammer it should slide off. May be stiff though.
Remove handbrake springs, shoes and wot nots remembering how it all goes back.
Attach The Bearinator to the hub using wheel nuts and slide the half shaft out.
Cut the old bearing off.
Fit new bearing by tapping and generally being patient until it all goes back together again.
At least thats the short version.
There is a write up somewhere but I cant find it.
Re: a rumbling i will go... by weave67 on Mon Jul 13, 2009 6:50 pm
thats what i was gonna say :roll:
Re: a rumbling i will go... by Dave_RAYNET on Mon Jul 13, 2009 6:52 pm
Phil,
having read the bearinator thread would you mind altering the thread title to "A rumbling it will stay" :shock:
Dave_RAYNET
Re: a rumbling i will go... by Sir-Doris on Mon Jul 13, 2009 6:53 pm
Go on then....
Honestly dave its not that bad really. It looks worse then it is. I changed CC's bearing on the drive in a little over an hour or so.
Re: a rumbling i will go... by Dave_RAYNET on Mon Jul 13, 2009 6:55 pm
Dave_RAYNET
Re: a rumbling i will go... by Sir-Doris on Mon Jul 13, 2009 6:59 pm
Not easily I shouldnt think but we have a bearinator at my house if your coming up for the undersealing party.
Users browsing this forum: No registered users and 70 guests
