Frontera Technical Support • View topic - leaving fog ??
leaving fog ??
leaving fog ?? by fogman on Tue Jul 07, 2009 4:58 pm
as some of you might know ive had some overheating problems so i took emily down to my mechanic, after a good look it was decided to strip her down & check the dreaded head gasket, if there was visible signs of damage then a skim & test would be carried out which all was duly done because the [ gasket was broken in 2 places ], the head passed its test ok so the rebuild has done however on completion & refilling the top hose is still pressurising & shes still loosing water ! ! !
just by luck :( but if theres nothing else members can suggest & it turns out theres a crack in the block etc then i think shes going to have to go, i cant really afford to then buy another engine,thats if i can even find another decent 1, & pay for delivery & then have it inplanted etc, i think i would have to cut my losses & either try & sell her or scrap her .
any suggestions would be appreciated guys :wink:
Re: leaving fog ?? by FUDDY MUCKER on Tue Jul 07, 2009 5:14 pm
Have the core plugs been checked ??? Especially the ones under the injection manifold, may have dislodged one or more of them slightly due to the over heating.
Re: leaving fog ?? by JueOmega on Tue Jul 07, 2009 5:20 pm
Is there water in the OIL.... Head / gasket / Block?
head tested ok, new HG ..Was the block tested for trueness ie across the bores
Are there any VISIBLE signs of water leaks externally ?
possible pipe spit or even a jubilee clip loose
Is the Carpet wet?
Possible heater matrix leaking
Is the thermostat opening
as the engine warms up, if the stat does not open it will pressurise the system
JueOmega
Re: leaving fog ?? by nigelbread on Tue Jul 07, 2009 8:01 pm
nigelbread
Modifications: +
Re: leaving fog ?? by Rifleman on Tue Jul 07, 2009 9:44 pm
Did your mechanic get the head skimmed when it was tested?
Re: leaving fog ?? by fogman on Tue Jul 07, 2009 11:42 pm
theres no leaks in the car, no leaks to be seen in the engine bay which i would assume would be the case if a core plug had beendislodged or moved etc through heat but having said that she never boilled up,she never ran any hotter than when the fan cuts in [approx 90 degrees ] & never into the red & the temp always went down when the fans cut in at the normal temp so i gota assume thats workin fine, its got a new stat so thats gota be ok as well. the head has been skimmed and checked
Re: leaving fog ?? by andysd1 on Tue Jul 07, 2009 11:50 pm
is your header tank ok, as we have just sorted simo-d car, his was losing water, and it had a small crack around the top just below the cap,
Re: leaving fog ?? by fogman on Tue Jul 07, 2009 11:55 pm
yeah the header tank appears to be fine
Re: leaving fog ?? by bobbinsjob on Wed Jul 08, 2009 5:10 pm
Sounds just like what was happening to Angelina at Bala. Turned out to be the bearing seal on the water pump. About £50 from motor factors
Re: leaving fog ?? by fogman on Wed Jul 08, 2009 6:20 pm
quick update guys, after visiting the garage today i learned that the water was being blown outa the rad almost immediatly after starting the engine& not loosing it as i assumed after the phone call yesterday which explains my mistake in my original post :oops: , so while watching the gusher flooding on to the workshop floor i suddenly remembered some advice given in a post advising to check the heater, so i did & it was only giving cold air, the heater pipe was then taken off & she was restarted, then it was noticed that the rad was only hot on 1 side so the fan was slowed roght down as it cut in, this somehow allowed the rad to fill completly with hot water,those 2 things seemed to of cured the problem because she stopped blowing water & the heater started to blow hot air :wink: im hoping it was just a persistant air lock !
after running for approx 30 mins without any noticeable loss of water i left her to be drained again tomorrow morning then reilled with 50/ 50 mix of water /antifreeze, then ran again for an hour or so before a test run and then after cooling down later in the day another level check.
im not 100% sure emilys ok yet but im feeling alot better than i did this time last night ! !
thanks for the advice & suggestions so far guys :wink:
i hope to report a happy ending tomorrow :roll:
Re: leaving fog ?? by jontera on Wed Jul 08, 2009 6:41 pm
good news,
fingers crossed for you.
once a fogger always a fogger...there is no turning back you know, you know that the fronty is best :dance:
Re: leaving fog ?? by fogman on Wed Jul 08, 2009 11:51 pm
wise words mate ill be double gutted if emily dosent pull through this :wink:
Re: leaving fog ?? by andysd1 on Thu Jul 09, 2009 12:02 am
good luck mate. keep us posted,
Re: leaving fog ?? by Roo on Thu Jul 09, 2009 2:01 am
Hi Fogman
Image hope she is ok for you Matey :dance:
Fingers crossed for ya :wink:
Re: leaving fog ?? by fogman on Fri Jul 10, 2009 11:56 pm
after picking her up yesterday pm, i had to top her up with a cup full this morning & now after running about all day [locally] including a trip to the p/o to purchase 6 months of car tax [more expense] having constantly checking the header tank & rad [when shes been cold enough] it appears that alls well & so emily is now back on the drive where she belongs.
at the moment im a very happy chappy but im sure that will all change again when i go to see charlie [ the mechanic] on monday for the bill :D
Re: leaving fog ?? by Road Hog on Sat Jul 11, 2009 12:04 am
Such are the joys of Fronty ownership,good on you for sticking with it bud :D :D
Re: leaving fog ?? by fogman on Sat Jul 11, 2009 12:13 am
thanks mate, some of the advice & suggestions from the guys genuinely helped me out so thanks again to everyone whos posted in all my various threads in the last few weeks reguarding overheating problems etc :wink:
i hope webby [a new member who is going through pretty much the same problems] is having some good luck as well
Re: leaving fog ?? by Roo on Sat Jul 11, 2009 1:08 am
Hi Fogman
That's great news Matey :dance:
Pleased for ya :D
Re: leaving fog ?? by Sir-Doris on Sat Jul 11, 2009 1:11 am
Good news fella... Hope it keeps up ;-)
Users browsing this forum: No registered users and 69 guests
