Frontera Technical Support • View topic - Rusty spanners
Rusty spanners
Rusty spanners by Adam on Tue Jun 23, 2009 8:11 pm
help found a load of rusty spanners that i want to bring back from the dead, should i soak them in petrol or have you any better ideas :cry: :cry:
Adam
Vehicle Name: Mini-Monty
Re: Rusty spanners by john (smifffy) on Tue Jun 23, 2009 8:14 pm
try wd40 or soak them in coke just dont drink it afterwards :D :D
Re: Rusty spanners by peej39 on Tue Jun 23, 2009 8:16 pm
Vinegar, is quite effective I believe.
peej39
Skype Username: paulw39
Re: Rusty spanners by Roo on Tue Jun 23, 2009 8:17 pm
Hi Adam :D
You could try WD40 then use a metal wire wool to remove the rust.
Good Luck Matey :dance:
Re: Rusty spanners by Drift on Tue Jun 23, 2009 8:18 pm
Re: Rusty spanners by Adam on Tue Jun 23, 2009 8:23 pm
should have seen the look on Nesse's face when i just asked if we have half a gallon of vinager spare.............taxi
Adam
Re: Rusty spanners by nigelbread on Tue Jun 23, 2009 8:23 pm
how rusty?
nigelbread
Modifications: +
Re: Rusty spanners by Adam on Tue Jun 23, 2009 8:26 pm
well they where chromb , now covered in rusty powder and sludge after something must have leeked on them a few years past
Adam
Re: Rusty spanners by nigelbread on Tue Jun 23, 2009 8:37 pm
If you have a cement mixer water and sand mix will clean them up, removing loose chrome and rust.
Then oil or paint, i did some of mine and painted imperial one colour metric another,
nigelbread
Modifications: +
Re: Rusty spanners by Sir-Doris on Tue Jun 23, 2009 9:29 pm
I used WD40 and wire wool on mine. After they have been used a bit they seem to shine up a bit and have that used look about them.
Re: Rusty spanners by subsonicnat on Sun Sep 27, 2009 4:46 pm
Hi Guys,
Been waiting to come across a thread like this:::::
All you need to get RUST OFF anything is Dead Easy, no WORK required::
1/ A plastic bucket: (Cannot be Metal)
2/ A NEW piece of Steel:
3/ A 12 Volt Battery or Battery charger:
4/ Baking SODA:
The POSITIVE goes to the NEW Steel: The NEGATIVE to the Rusty (PART):<> (Which must have good Contact):
Put A Cane or piece of wood across the bucket to support the NEW Steel and PART to be Derusted: String will do.
Fill Bucket with TAP water, put one big heaped TABLESPOON of Baking Soda in the bucket: CONNECT WIRES to Both Parts:
(Better if it is a Battery charger try to keep clips out of the water):::
This Idea works with LINE OF SIGHT,,, So if the Part is round CURL the NEW Steel to suit the Rusty part All Round:::
Over a few hours the rust will LEAVE the Rusty Part and ATTACHE its`self to the new metal:::
The RUSTY part will OXODISE to DEEP BLACK, it must be WIPED with ,, Like,, Paper Kitchen Towel and dried you can use a hair Drier then, BUT, ::: IT MUST BE PROTECTED "IMMEADIATLY" as it will try to turn rusty again:
I did this with some Headlight Backs once as they were very thin, they come up like brand NEW::
Even if you do not Require to use this,, TRY IT, you will be amazed how it turns out.. :shock:
Do Not forget >>>>>> PROTECT it quickly, once dry UNDERCOAT/PAINT/ or /OIL/Grease/..
It will be like Brand NEW.. Hope you understand what I have Written:
Colin:Norfolk: (Subsonicnat).
PS::: Been So long since I did this not sure which way the Polarity is, but it doesn`t matter a couple of hours will tell you if its working if not REVERSE the Leads.. :oops: :oh yer:
subsonicnat
Model: 2.5 TDS Transglobe 5dr
Vehicle Name: Beast
Modifications: I Did Clean it.?.. And Yes, it does have aircon.
Re: Rusty spanners by nigelbread on Tue Sep 29, 2009 9:54 pm
Parts:put one big heaped Baking Soda in the bucket:
table spoon or?
Then i will try.
Thanks for the info
Nigel.
nigelbread
Modifications: +
Re: Rusty spanners by MyMu on Wed Sep 30, 2009 12:02 am
Vinegar :shock: I did not believe you so I had a google.
http://www.graveldraggers.com/index.php?option=com_content&view=article&id=38:tech-vinegar-rust-removal&catid=2:dangerous-contraptions&Itemid=7
Does anyone have a bucket big enough for my truck to sit in :lol:
MyMu
Modifications: 2.5" body lift,
3" suspension,
16 x 8 Alloys, 50mm spacers
265 75 16 Insa Turbo track edge
Rock sliders, Ball joint flip,
lowered front diff,
3.1 intercooler & rad,
Uprated turbo, Fuel pump tweeked
EGR blanked
Trooper axles with LSD,
Electric, heated leather seats
External roll cage, Winch bumper,
A/C converted to onboard compressor,Manual hubs,
hand painted matt black
Roof rack with 4 front lights & 1 rear
Re: Rusty spanners by subsonicnat on Wed Sep 30, 2009 12:17 am
Hi Mate,Funnily enough years ago they used to use this method as a (SLAVE) to rot away, so your car did not..
Not so far off the mark at all mate.. Let me know how you get on. :mrgreen:
Its worth it just to see it in action..
Colin:Norfolk.
subsonicnat
Vehicle Name: Beast
Re: Rusty spanners by Frenchfarmer on Thu Oct 08, 2009 1:33 am
Frenchfarmer
It works!!!!
