Frontera Technical Support • View topic - Oil change pumps
Oil change pumps
Oil change pumps by olympus16270 on Mon Jun 15, 2009 2:54 pm
Hi boys & girls,has anyone used one of these electric oil change pumps that connect to car battery and suck out the oil via the dip stick hole.
I have just changed the oil on my Fronty and had a bit of a job removing the cover panel underneath the sump.
I have seen these pumps advertised over here in France for 15-20 euro so thought it might make life easier next time.
A bientot,
John
olympus16270
Model: 2.2i Sport Olympus 3dr
Vehicle Name: Beryl
Re: Oil change pumps by john (smifffy) on Mon Jun 15, 2009 2:56 pm
Re: Oil change pumps by Rifleman on Mon Jun 15, 2009 3:13 pm
As above, and you will get more or less all the oil out via the sump plug as the sump is shaped so it flows towards and out of it. You wont if removed via the dip stick tube.
Re: Oil change pumps by olympus16270 on Mon Jun 15, 2009 3:25 pm
Thanks for replies,on this 2003 model 2.2 Olympus there is no hole beneath the sump plug and it was necessary to remove the plastic cover from under the sump to access the sump plug,I had to remove 2 nuts from the rear of the plastic cover and loosen 2 bolts from the front of the plastic cover as it slotted under the front metal plate.
Then it started raining as I was under the car-typical!
As I intend to change the oil and filter more regularly I thought the pump may be a good investment and timesaver.
Has anyone used one and do they do the job?
A bientot,
John
olympus16270
Vehicle Name: Beryl
Re: Oil change pumps by john (smifffy) on Mon Jun 15, 2009 3:26 pm
i use one to drain & refill gearbox & diff but never engine
Re: Oil change pumps by Rifleman on Mon Jun 15, 2009 3:30 pm
Can't you cut an access hole into the cover? That would make things a lot easier.
Users browsing this forum: Google [Bot] and 45 guests
