Frontera Technical Support • View topic - Govt. reveals 130,000 in the WRONG council tax band
Hi :D
I know I've posted this before in the past, but seeing as there are a few more new members ... This maybe of use to some of you :dance:
Check 'n' challenge your band NOW & reclaim £1,000s
Great news in the Sunday Telegraph; it reports that, over the past three years, this site's “Check 'n' challenge your council tax band" campaign has been the major player in the rebanding of 130,000 homes. On those numbers, it's possible nearly 1 MILLION people in the wrong band could get it lowered, with backdated payouts hitting their pockets.
Why you could be in the wrong band. In England and Scotland, bands were initially set in 1991 by a rush job to withdraw the poll tax. Unbelievably, valuers were sent in cars doing ‘second gear' valuations, where they allocated thousands of bands while driving by. Yet, shockingly, it's never been redone.
Check 'n' challenge only takes ten minutes. There are two simple steps: first compare your band to neighbours in similar properties. This is easy, as it's all public data available instantly online. If that shows you’re overpaying, then simply work out your home’s value in 1991, using free web tools. Full step-by-step guide: Council Tax Rebanding
Get a backdated payout. If your property’s rebanded, not only will you save £100-200/yr, the refunds are backdated, possibly to 1993 when council tax was instituted. We’ve had scores of people reporting payouts in the £1,000s, with one street even being collectively rebanded, and getting £100,000 back. Read Success Stories: Council Tax Rebanding
We’re very proud of the rebanding campaign. It started with a perfect mix of the forum and main site, as we developed, then honed, the technique with amazing feedback from forumites. It's now great to see that, over the years, the success has had a nationwide impact.
The information can be found on .... http://www.moneysavingexpert.com
Good Luck :dance:
:ggod post: :ggod post: :ggod post:
tez1963
Modifications: none
in between trucks
at moment !
i did it last year thanks to martin thingy on gmtv
but be warned they will try to make it difficult for you they were shocked when i turned up at the tribunal i got £786 back and £103 less a year
never give up
olympus lwb 2003 2.2 dti
hawk
Modifications: uprated shocks & brakes
under sidestep lighting
Users browsing this forum: Google [Bot] and 55 guests
