A Bit Off Topic
A Bit Off Topic by alsavs on Tue May 26, 2009 2:07 pm
I was just wondering if there any Renault Mechanics registered to this forum who might be able to help me out.
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: A Bit Off Topic by Roo on Tue May 26, 2009 2:59 pm
Hiya
I have Clio :wink:
May I ask please :D .... what are you having problems with?
Re: A Bit Off Topic by alsavs on Tue May 26, 2009 5:38 pm
Hi Roo its to do with the air con not working.There is a known problem regarding something getting blocked causing it to fail they would not say what the problem is.Renault said if i take it down and they put it on there diagnostic kit and the error code is the same has known problem no charge but if it comes up with a differant error code they will charge me.All fuses seem to be ok and the system is all gassed up ok.
Alan.
alsavs
Re: A Bit Off Topic by mikovitch on Tue May 26, 2009 5:42 pm
Its not a scenic is it? I know the pressure sensors go on those.
No More Nails, Duct Tape and a big hammer. Who needs a tool kit?!
mikovitch
Modifications: I have currently modded it so much that is looks suspiciously like a Hilux 3.0l diesel with a 2 inch lift and BFG's hehehe ;) Oh ok, I lied. It IS a hilux. I will be getting another shorty soon tho.
Re: A Bit Off Topic by alsavs on Tue May 26, 2009 5:56 pm
Sorry should have said its a 06 megane.
Alan.
alsavs
Re: A Bit Off Topic by Roo on Tue May 26, 2009 6:02 pm
well If I was you, I let them do the check seeing as its free, and see what they come back with.. but I would tell them not to do any paid work on it yet, as it maybe simple to fix yourself ..
I guess you've checked the gas in the air con system ?
I know that the gas in the air con system usually needs to be re-gassed every three years or so. otherwise the system does not work..
Hope that is of some help to ya :D
Let us know please :D
sorry just read your post again, and you say the gas is fine.. Just off to find yet another :wall:
could there be a leak in the condenser (radiator).??
Re: A Bit Off Topic by alsavs on Tue May 26, 2009 8:00 pm
Thats the problem its only free if it turns out to be the known problem other wise they will charge.
Alan.
alsavs
Re: A Bit Off Topic by Road Hog on Tue May 26, 2009 8:35 pm
Nip into Argos & buy their reader (about £45) it comes with money back guarantee,plug it in & make sure it works before leaving the car park,can be a bit fussy these French motors :wink:
Re: A Bit Off Topic by alsavs on Tue May 26, 2009 10:39 pm
Your right there A friend we plugged a Bosch Reader in there surpposed be all singing and dancing model and it did not recognize the car.
Alan.
alsavs
Users browsing this forum: Google [Bot] and 52 guests
