Hi,
New to the forum - I dropped in looking for advice as I'm considering replacing my 300Tdi Discovery with a B series LWB. The Discovery has been a pretty good car, but it's not going to pass it's MOT without a lot of money spent (mainly on welding). I like Land Rovers, but the options within the age range I'm looking at (P38 Range Rover and Discovery 2) are both stretching my budget and inclined to non-DIY friendly electrical gremlins, so I'm looking at other options.
We took a 2.2 Petrol, manual LWB out for a test drive yesterday, and it seems like a reasonable option. This particular car had a few electrical gremlins (dodgy instrument cluster, which I see is a common fault), airbag and ABS faults as well as a couple of other minor things and a few patches of rust. To be fair it was an unprepped car at a second hand car dealer, but I think I'll be passing on it. I was pleasantly surprised by the 2.2 petrol - it didn't feel as slow as I expected, at least around town (I didn't push for a run up the motorway - one of the faults was a half flat tyre...), though it certainly wasn't a rocket car.
According to a friend who used to work for Vauxhall the 2.2 petrol is a good engine, 2.2 diesel is average and the V6 he's had bad experiences with but suspects the car he had had been clocked. He also said the Frontera wasn't much cop off road.
The car will be used for a 40mile round trip commute every day, mostly motorway and open roads, and as a general workhorse. It'll occassionally be used for moderately heavy towing, on road and round fields, and a bit of green laning. Basically an all round work horse.
Aside from the instrument cluster, is there anything else I need to watch out for on the B series trucks?
I was originally thinking that a diesel was the obvious option, but on paper the 2.2 petrol is a bit quicker and shouldn't be much more costly to run - how does it compare in the real world? I could imagine the 2.2 petrol is a bit lacking in torque off road, but I couldn't shift the transfer box into low, and I know the Discovery is a completely different vehicle in low range. What is real world fuel consumption like with a V6? Think they're going to be too thirsty, but the much better performance is certainly attractive!
The transfer lever was completely solid, wouldn't move at all - is this normal for a truck that's never been in low? How hard is it to free off? You get the same problem with Land Rovers, but there's usually still a bit of movement in the lever, it just won't engage low.
What about off road? I would imagine the long wheel base is a handycap (SWB isn't big enough inside to be an option). What underbody protection is advisable on a Frontera? What about recovery points and the like?
What are Frontera's like on the motorway? Are they working a bit hard (as the Tdi Discovery is) and a bit on the noisy side, or are they fairly relaxed cruisers?
TIA,
Geoff
