Frontera Technical Support • View topic - Confirmation needed ...
Confirmation needed ... by Alchamist on Thu May 21, 2009 4:15 pm
Hi guys,
This might sounds daft, but can someone confirm (as in by experience) if a disconnected lambda sensor makes the EML light come on please ...
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 4:54 pm
Hang on a moment will unplug wifeys & see :wink:
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 5:01 pm
Tigra B with precat Lamda NO warning lights when disconnected with engine running :? Can somebody please try it on an A series to make double sure :wink:
Re: Confirmation needed ... by Krusher on Thu May 21, 2009 5:13 pm
Lambda sensor is the one in the exhaust just before the cat YES/NO?
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 5:17 pm
Yep thats the kiddy :D
It will probably give you a lumpy tickover when disconnected but will not harm anything in the short time :wink:
Reason: added second text line
Re: Confirmation needed ... by Krusher on Thu May 21, 2009 5:18 pm
In that case, No if disconnected it does not put on EML on X20 engine
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 5:26 pm
Cheers bud, :D
Jay,I think it only shows EML for post CAT Lamda,on more modern Vx it has a seperate Emissions light for non critical faults
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 6:04 pm
Hmm, dagnammit. Thought i might have been getting a step closer to finding the fault with mine. Back to the drawing board I go ...
Thanks for checking guys - I really appreciate it. Every other sensor throws the light on when disconnected, and as I get the "oxygen sensor low voltage" error, so thought I might have been in the ballpark at least!
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by Drift on Thu May 21, 2009 6:39 pm
The light deffo will come on with it disconnected, Ive done it on my old sport.
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 6:41 pm
Ok, now i'm confused! :lol:
Are we saying that on the C20NE engine, the EML light should come on if the lambda sensor is disconnected, and can we verify that at all please?
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by 4x4 bobby on Thu May 21, 2009 7:13 pm
I did and Alex agreed with me !
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 7:17 pm
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 7:19 pm
Re: Confirmation needed ... by 4x4 bobby on Thu May 21, 2009 7:57 pm
Re: Confirmation needed ... by alex on Thu May 21, 2009 8:26 pm
Perhaps the cable or loom from it could be impinged.
Re: Confirmation needed ... by 4x4 bobby on Thu May 21, 2009 8:28 pm
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 8:29 pm
Impinged? Sounds painful! :lol:
This is why I wanted to check to see if the EML light should come on with the sensor disconnected - as if it's not registering the disconnect, then there could well be a short along the line, which would also explain why my engine is running exceptionally lean.
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 8:30 pm
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by 4x4 bobby on Thu May 21, 2009 8:36 pm
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 8:38 pm
The sensor is brand new - and with the fact that the ECU is not picking up the disconnect, then I am leaning more towards the wiring, and it was doing the same with the original sensor as well
Jay
Alchamist
Modifications: .
* CB
Users browsing this forum: Google [Bot] and 45 guests
