Hi,
As I said in my last or as it be first post, there are lots of skepticism about HHO and as explained I see it everyday in many forums.
There are good ones and bad ones (unfortunaltly more bad then good).
The device is safe for normal road or cruising marine use but off road it would cause a few issues.
Saying that it would be fine while on the road but as soon as you go off road I would turn unit off and have water level at a low before performing any off road fun.
We have many good results with the systems we fit and there is a governing body developed for this.
We have insurance approved status and Compliance from the DVLA to have it registered.
The manufactures of the system are and have been in talks with VOSA for testing over the last year and getting closer to having a status. This status will be one of the first of its type ever after so many companies have failed in the past.
You mention why if this technology is so good that it hasnt worked well for over 100 years, well that is because only until recently the system or the way the technology has been developed has had several floors that were never fixed, these systems are available just like the plans to make them all over for as little as 99p or even free. (there is a reason for this, that is because they have as much chance of working as our present government)
I myself started fitting these as trial only and if the owner of the vehicle was happy then they can pay for it after 14 days. I have only had to remove one system so far and that was because I should have known better as the van it was fitted to had almose every mod possible and it never had a chance. (HID lights, performance remap, lots of flashy lights, a driver who thinks he was on a race track all the time, carrying over a ton as standard and other factors)
It wasnt that it didnt work but for the fact it was going to cost £699 and he was only getting a max of 6% gains, meaning it did work but to him who wasnt prepared to change his ways it wouldnt be worth it and buying £699 worth of diesel would ave been the better option.
Others have reported on constant use with same driving conditions and miles covered that they get between 20 and 36% gains. Never a negative result.
Infact I've been busy the last wek or so fixing frozen systems due to this cold weather which cought us all off guard.
Luckily there is a simple fix in the design which means if it goes below -10 then the seals pop to let out the expanding ice so save the other components from being damaged.
Due to this happening I had calls to say my milage has gone down and there must be a problem please can you check the system over. (same issues were to most of the systems the last couple of weeks)
There is a solution to combat this but because the cold came very quick this year the usual advisory email was beaten by the cold so damage was done.
using Isopropyl Alcohol (Rubbing Alcohol) the system can be saved from freezing and still work ok.
I think I'm a fair person and haven't used forums to advertise my company and will continue to not mention any names. If anyone wants to know these then I would answer any pm's.
I would also like to point out that I would be frownd upon by using names without the consent of the companies involved due to the many previous arguments on forums for the for and against sides and views people have.
All I can say is that there are people out there who read so much rubbish that they think they know everything yet when asked if they have tried a system there answer is usually no. All I can say is that no matter what vehicle I use or own it will always have a system fitted if it can be done so to anyone who is prepared to put the technology down the at least try it first before trying to argue the point.
I would like to fit a system to a Fronty once the weather gets a little better.
I would also like ot appologise for my speling and typing as I'm rubbish and my sausage fingers are very clombsey.
