Frontera Technical Support • View topic - Farm jack?
Farm jack?
Farm jack? by DARREN40 on Mon May 18, 2009 5:14 pm
Hi to one and all
just aquired a farm jack foc off a local old boy , unused and still in box was told when he dragged it off his mobility scooter :) :)
says got no use for this so thought you maybe able to use it :D :D , have never used one before so maybe you could help ?
by answering some questions on this ?
1) where can i use a jack like this?
2) are there any good places to jack a frontera using this?
looks a good piece of equipment if can work out the best places to jack on??
sorry to ask maybe a silly question( hopefully not) but dont want to damage or injure me or fronty
regards and looking forward to you wise answers
darren
if i can i will but if you dont ask then i dont know
best wishes to all fog members everywhere from my little bit of bristol
DARREN40
Registration Year: 1994/M
Vehicle Name: STREETHAWK
Modifications: K&N FILTER WITH RE ROUTED AIR FEED , UPRATED GAS SHOCKS FROM OZ ( AS ADVISED BY MATE IN OZ ) NOW LIFTED 2" ALL ROUND AND OTHER MODS include
6 SPOT LIGHTS ADDED 2 X DIPPED/ 2 X HI BEAM + 2 X 9 INCH INDIEPENDENTLY SWITCHED FOR OFF ROAD USE, CHANGED SIDE REPEATERS TO LED (SMOOTHER LINE STYLE ) MORE TO COME YET !!!! NOW RAISE HER A LITTLE , STOPS HER BELLY SCRAPING THE MUD, (HOMEMADE KIT) led dash conversion complete now on to other mods SWITCHES NOW BLUE BACKLIT CB AND 6FT WHIP ON CLIP MOUNT now have some nice mud tyres (31/10.5/15) now have upper lights wired for stop/tail !!
Re: Farm jack? by Rifleman on Mon May 18, 2009 5:18 pm
The answer to question 1 is easy Darren.
A farm.......... :D :D :D
Re: Farm jack? by john (smifffy) on Mon May 18, 2009 5:23 pm
do you mean one of these
Re: Farm jack? by DARREN40 on Mon May 18, 2009 5:41 pm
YES THOUGHT THAT ONE WOULD COME OUT LOL
YES SMIFFY ONE OF THEM BEASTS
DARREN40
Re: Farm jack? by john (smifffy) on Mon May 18, 2009 5:59 pm
Re: Farm jack? by DARREN40 on Mon May 18, 2009 6:06 pm
ok thanks as have worked out rear can be lifted by using towbar , didnt even know there were holes for jack under bumper lol
anymore advice on this welcome :D :D
DARREN40
Re: Farm jack? by Road Hog on Mon May 18, 2009 7:50 pm
Thinking on Sir Doris has been trained in hi-lift jacks as part of his 4x4 response thing,will point him to this thread :wink:
Re: Farm jack? by Trugga on Mon May 18, 2009 9:46 pm
You have to be careful when using a farm jack/hi-lift as they are inherantly unstable:
They can also be used as a come-a-long hand winch:
Re: Farm jack? by Sir-Doris on Mon May 18, 2009 11:35 pm
As Trugga pointed out they are inherently unstable and should not be used to jack your vehicle up unless absolutely necessary.
When using the jack ALWAYS keep hold of the handle as if it is let go before the ratchet mechanism has a chance to lock it, it can and will swing back and hit the jack with force. It can break bones and disfigure faces.
When the vehicle is jacked up it is advisable to keep the handle in the upright position and secure it to the forged section with a bungee cord etc.
Farmjacks are used to winch, lift, pull, lower etc and a typical jack is rated up to 3 or 4 tonnes.
Always keep people away from you when working with a farm jack, as they are quite unstable they can 'pop' out and spring away from you.
There are no jacking points on the frontera apart from the rear towbar as you have discovered. You can use the round chassis protrusions on the front of the vehicle but I doubt the suitability of these points as the tubes arent very deep.
Another example of their use: Say you are stuck in deep ruts you could jack up the front of the vehicle so the wheels clear the ruts and push the car sideways, this will hopefully leave your car with the front wheels straddling the ruts and you can repeat for the rear wheels allowing you to continue. Again be wary of the jack as it can spring out when the vehicle is pushed sideways.
Read the instruction manual thoroughly and familiarise yourself with all the working parts. There are plenty of tutorial and safety literature available on the web.
Re: Farm jack? by priestinthejeep on Mon May 18, 2009 11:47 pm
top idea to use it as a winch
priestinthejeep
Re: Farm jack? by DARREN40 on Tue May 19, 2009 8:18 am
THANKS TO ALL WILL TRY TO SORT OUT HOW TO USE IT BEFORE I GET STUCK LOL
OFF TO GOOGLE NOW :D :D
DARREN40
Re: Farm jack? by yaki on Wed May 20, 2009 12:36 am
Just a few pointers in addition to Phils comments especially if you are on soft ground
Use some wheel chocks to stop the truck moving
Don't lift it using the centre of the towbar, getting both wheels off the ground by this method is very dangerous and won't take much to have it fall sideways
Get a jack pad, highlifts on soft ground will sink, you can buy pukka plastic ones but at £35- or so they are expensive, I made one for nowt out of 3 pieces of 3/4" shuttering plywood glued and screwed together with a cut out for the foot
Have used mine as a makeshift winch using some shortening chains, slide waffle boards under the wheels when stuck in the mud, fit body lift pucks as well as changing wheels. Did try to use it as an engine crane once but failed :lol:
You can jack it on the front bull bar if you have a steel one fitted.
Re: Farm jack? by DARREN40 on Wed May 20, 2009 9:20 am
HI THANKS FOR THAT WILL TRY OUT WHEN I HAVE A BIT OF SPARE TIME
HAVE TAKEN ALL COMMENT ON BOARD AND STILL WILL TO ACCEPT MORE??
DARREN
DARREN40
Re: Farm jack? by Road Hog on Wed May 20, 2009 9:26 am
Darren,you are just plain greedy :lol: :lol: :lol:
Please turn CAPS LOCK off as text all in caps is seen as shouting in forums :wink: Cheers bud :D
Re: Farm jack? by DARREN40 on Wed May 20, 2009 6:55 pm
well if you dont ask :D :D :D
sorry about cap on earlier posts step daughter keeps pinching the caps lock key lol
many thanks ans humble sorryness to all :oops: :oops: :oops:
DARREN40
Users browsing this forum: Google [Bot] and 45 guests
