Frontera Technical Support • View topic - anyone know about ford tractors mechanical??
got her on wed used it few times till sunday morning it wouldn start due to flat battery charged battery and checked it all out n found out its the altenator does anyone know if any other will fit ford cars ect
its a 1985 ford 8210
priestinthejeep
no, i dont know :wink: :D
I reckon the oodizard will help on this one :wink:
Thats Woodwizard .. just wanted to see what it looked like without the W's in :oops:
He is very countryfied as A friend is but he is away at the moment :wink:
They don't have the 8210 listed, but these guys might be able to help:
http://www.agrilineproducts.com
(They're not too far away from my place of work)
HTH
almost any car alternator will do you need to check mounting configuration, pulley diameter and projection and wiring layout.
Alternators are generally left or right handed, find one with built in regulator for ease of wiring.
Old lucas as fitted to brit cars is very easy to adapt reversable for left / right fitting and two wire electrics.
nigelbread
Modifications: +
Only used John Deere and they never went wrong, so can't help much. Did you do an alty test or could you have a battery drain elsewhere.
thanks lads il have an idea wat im lookin for now,yea defo the alty dad is a sparks n he checked it out
:party: :party:
priestinthejeep
a set of brush's might fix it
never done the brushes on anythin before is it worth while doing them or just gettin another alty
priestinthejeep
Don't know mate but these guys will http://www.farmingforum.co.uk. The next best thing to FOG :lol:
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Classic tractor by the way, is yours the SuperQ 4wd? Used to drive a SQ 4wd 7610, really miss that tractor :cry:
furio
Roof lights
priestinthejeep
got a alty off a scrapd fiesta for free try that and see thanks guys
priestinthejeep
i used an alterntors off rovers on a few of my fords
il keep that in mind in case the other one fails
priestinthejeep
Users browsing this forum: Google [Bot] and 45 guests
