[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Comments on the Thundertruck Here Please
Looks good - where did you get the roof lights and the roof rack?
Cheers Paul
Only two things needed in this world.... WD40 and duct tape ..... if it doesn't move and should , use WD40 . If it does move and shouldn't , use duct tape - see easy!!
