Speedo cable quickie...
Speedo cable quickie... by Wilberforce on Tue Apr 21, 2009 6:37 pm
Wotcher folks...
Whilst I was patiently sytipping bits off my dead LWB yesterday, I had one of those "eureka" moments, and decided to liberate the speedo cable, seeing as I was taking the dash apart anyhow.
The reasoning is that Sophie the SWB lacks for one, cos it had a bit of an accident :oops: Anyhow, just to check, is a speedo cable a speedo cable is a speedo cable?? No differences depending on the model / engine??
Cheers,
Jim
Re: Speedo cable quickie... by andysd1 on Tue Apr 21, 2009 6:41 pm
if it fits both ends it will be fine
Re: Speedo cable quickie... by FUDDY MUCKER on Tue Apr 21, 2009 6:42 pm
Correct, cos the cable go to the gearbox, not the engine, and as far as i know the attachment on the gearbox is in virtually the same place on all models.
And if worst case, it is slightly too long, just loop it out a bit more in the engine bay. :wink: Its only got to connect to point (a) and point (b) the bit in between just goes through the engine bay and down the side of the box.
Re: Speedo cable quickie... by Wilberforce on Tue Apr 21, 2009 6:45 pm
Jolly good, that's the answer I like to hear :lol:
Cheers Andy & Jase. Be out under the car again tomorrow; might even work out where all the oil's leaking from, too :D
Cheers,
Jim
