Can anyone Help!!!
Can anyone Help!!! by colley on Wed Apr 15, 2009 7:11 pm
My wife came home in her zafria 1.8 petrol today saying the car has lost power and is struggling to start :cry: So i took the car round the block.
the car really struggles to accelerate and hesitates. the car also has a warning light on the dash and when checked in the book it says its emissions fault and should take it to vauxhall asap :( Just thought i would try my luck on here to see if anyone has any ideas.
Re: Can anyone Help!!! by Drift on Wed Apr 15, 2009 7:37 pm
Mass Air Flow Meter ( MAF ) faulty sounds a likely course, if Im not mistaken the 1.8 is not to dissimilar to the 2.2 Frontera engine.
Re: Can anyone Help!!! by woodwizzard on Wed Apr 15, 2009 7:45 pm
How old is the car? Lambda sensors have got alot to answer for. If the car is newish, get in, put your left foot on the brake and push the throttle to the floor with your right at the same time, then turn the ignition on but don't start the car. If it has the same set up as my astra you will get the fault codes displayed where the milometre is. Write them down and post 'em up.
Re: Can anyone Help!!! by Road Hog on Wed Apr 15, 2009 9:20 pm
Emissions fault is normally measured by ECU pre/post cat & is generally gobbledeegook for ... stuffed lambda
Re: Can anyone Help!!! by bobbinsjob on Wed Apr 15, 2009 11:27 pm
moved from LOUNGE to GD
Re: Can anyone Help!!! by colley on Wed Apr 15, 2009 11:58 pm
Well drift you was spot on :D :D did not manage to remove the air mass metre due to me having a trapped nerve in my back but did remove the pipe and gave it a good spray with wd 40. a few turns of the key later the car was running perfect and even the warning light went out.
I have give the car a run around the block and all seems well but still slightly hesitating on start up so think it may need changing or there may be a gremlin in there somewhere will just see how it gos for now. drift when i see you at bala will have one of these :drink: waiting for you as long as my back is better.
i will be gutted if i miss bala :( :(
have all ready made room on my fire place for the fog trophy :lol: :lol: :lol: :lol: :dance:
Thanks for the replies guys
Re: Can anyone Help!!! by Postfinder on Thu Apr 16, 2009 2:41 am
Glad your sorted Ste, watch that trapped nerve, you might get it untrapped and have to come back to work :lol: :lol:
G.
Postfinder
Modifications: The biggest hazard to my truck is Me.
"there is nothing wrong with getting a Sport airborne, bad things only happen when you land"!!
Re: Can anyone Help!!! by Drift on Thu Apr 16, 2009 7:28 am
:dance: go to Bala anyway and sleep flat on the floor of your tent, good for your back apparently :party:
Re: Can anyone Help!!! by Sir-Doris on Fri Apr 17, 2009 1:31 am
Another thing to check is the throttle body, give it a good clean out with a toothbrush and some carb cleaner/WD40. Common fault on these engines.
