What's this pipe? need to know to swap
What's this pipe? need to know to swap by paul4be on Tue Apr 14, 2009 6:58 pm
Just spotted this pipe (centre of pic, the rusted one that doubles back on itself) under the rear left corner, ('99 2.2i). I'm assuming fuel return or similar?
Also presuming that it's not high pressure by the use of spring clips to join.
I want to swap the whole section for new hose, but need to know what it actually is, and if possible, confirmation that it's low pressure, just to get the right hose!
Pic:
http://i77.photobucket.com/albums/j71/s ... gro023.jpg
Thanks all.
paul4be
Re: What's this pipe? need to know to swap by meooo on Tue Apr 14, 2009 7:44 pm
It looks to me to be either the tank breather pipe or ant-spill pipe (in the event that the truck over-turns it makes an air lock), so no, there should be no pressure...but make sure you refit the valve correctly or you will have problems filling the tank. :wink:
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
Re: What's this pipe? need to know to swap by JueOmega on Tue Apr 14, 2009 10:07 pm
Looks like this to me, hope it helps
JueOmega
Re: What's this pipe? need to know to swap by paul4be on Tue Apr 14, 2009 10:33 pm
Thanks, having looked again and looked at the diagram above, presume it is indeed a breather or similar outlet off the above tank evaporation system (pipe 9?).
paul4be
Re: What's this pipe? need to know to swap by meooo on Wed Apr 15, 2009 8:36 pm
no its not number 9, I can't export the picture from my copy of EPC3, but your pipe is at the filler pipe end and appears to be part of the filler neck (no part number for the metal pipe indicated)...but it is the tank breather system
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
