cant get in my fronty
cant get in my fronty by spud77 on Sun Apr 12, 2009 8:17 am
My central locking is not working, the drivers door key half turns but not enough for the door to unlock (I can get in through passenger door thankfully) but because I cant unlock the drivers door I can not open it to remove the interior panelling any suggestions
my new fronty[/b] Image
spud77
Re: cant get in my fronty by woodwizzard on Sun Apr 12, 2009 8:21 am
See if you can pull the rubber strips out each side of the window to try to get a piece of wire in and pull the lever up. Might be worth a squirt of WD40 into the lock.
Re: cant get in my fronty by Trugga on Sun Apr 12, 2009 8:24 am
I had this problem a few weeks ago - most likely is a little spring has snapped on the lock mechanism.
I managed to bull back the door card enough to get my hand in and release the lock manually, then open the door and replace the spring with the one from the passenger side.
Here's my posting at the time: viewtopic.php?f=8&t=21865&p=250018&hilit=spring#p250018
Lawrene
Re: cant get in my fronty by spud77 on Sun Apr 12, 2009 8:33 am
exellant post will give that a try and let you know how it goes
spud77
Re: cant get in my fronty by kareng on Sun Apr 12, 2009 9:10 am
if its just stiff, fire some wd40 in it. Thats what i did, and it works properly now. If its broken, then pass! Dunno.
kareng
Region: Northern Ireland
Re: cant get in my fronty by alex on Sun Apr 12, 2009 10:57 am
I had the same prblem as Lawrence, lots of patience with coathangers and the like got it open, right PITA only happens at night and raining.
Re: cant get in my fronty by spud77 on Fri Apr 17, 2009 6:15 pm
spot on Lawrence, that darn spring was snaped
Thanks alot all I can now get in through the drivers door :D
spud77
Re: cant get in my fronty by Trugga on Fri Apr 17, 2009 8:45 pm
Excellent news (and glad to of helped)
