Frontera Technical Support • View topic - Snapped bolt
Snapped bolt
Snapped bolt by BadBoy on Fri Apr 10, 2009 12:56 pm
Just snapped one of the bolts holding the body to the chassis while doing a body lift (not enough wd40 me thinks :cry: ).
Tried drilling it out but cannot drill it straight enough.
It is one of the back ones on the outer edge.
As there is another very close to it, does anyone think I would get away with leaving it out for a while until I can figure out how to remove it, and fit the new one & spacer?
I appreciate it is needed, otherwise it would not be there in the first place, but it this a mot failure type problem or can I make do for a while?
Skype Username: paul.bush21
Re: Snapped bolt by alex on Fri Apr 10, 2009 4:15 pm
Several options...
Leave it (I did, but couldnt condone it on here)
Get a steel puck to replace whatever you have, drill and tap it a conveniant size, bolt a bolt though the chassis and rubber puck to the new bolt with it sat up against the body.
Then finish the lift, once the others are tight the one only sat on the body will be tight up and bolted to the chassis, tack weld the puck to the body in situ and jobs done.
Last option is to lift the whole body off to get enough space to drill it out.
Re: Snapped bolt by alex on Sat Apr 11, 2009 9:07 am
I'm a bit lost here, but recieved this, (not from p8push I must say).
you might find it funny to mock the inflicted with your reply to snapped bolt in brackets,there is a law against that its called discrimination.I dont go behind peoples backs so i will tell you i have complianed about your insult to the admistration of this sight,i will also be complaining to the ISPA about this matter.
Ive read my reply, but cant see who I mocked or how? some help please folkes....
Re: Snapped bolt by weave67 on Sat Apr 11, 2009 9:13 am
well your always mocking me :roll:
Re: Snapped bolt by weave67 on Sat Apr 11, 2009 9:15 am
Re: Snapped bolt by weave67 on Sat Apr 11, 2009 9:16 am
Re: Snapped bolt by cheekychick on Sat Apr 11, 2009 9:17 am
I thought it was a fair answer, you gave him options, no mocking that I can see. :?
Do we get a prize if we guess who sent the PM?... Oh Weave thinks the same as me :lol:
Re: Snapped bolt by weave67 on Sat Apr 11, 2009 9:19 am
i have my uses kyle,besides sitting around camp fires and getting drunk :roll:
Re: Snapped bolt by cheekychick on Sat Apr 11, 2009 9:25 am
Don't have me getting a :offtopic: again, you'll have me in trouble again
Alex, I really wouldn't worry about it, especially if it was off farmer. Lets wait until p8ush comes on and says if he thought you were being 'discriminative' against him.
As a side note, whoever sent to PM needs to understand what discriminate means :roll:
cc
Re: Snapped bolt by weave67 on Sat Apr 11, 2009 9:30 am
:ggod post: :clap:
Re: Snapped bolt by Road Hog on Sat Apr 11, 2009 9:44 am
Re: Snapped bolt by cheekychick on Sat Apr 11, 2009 9:47 am
I like that, really good description, I for one vote that all posts not relating to the original topic are scrapped, and we don't rise to it, and we wait for p8ush to come back and let us know how he got on :wink:
Re: Snapped bolt by Road Hog on Sat Apr 11, 2009 10:07 am
Re: Snapped bolt by priestinthejeep on Sat Apr 11, 2009 1:15 pm
hi mate
if ya can get your hands on one of these it mite do the job
copy and paste this like into your browser
http://cgi.ebay.co.uk/RIGHT-ANGLE-KEYLE ... 240%3A1318
priestinthejeep
Re: Snapped bolt by BadBoy on Sat Apr 11, 2009 1:23 pm
All,
I have just complete the lift following Alex's advice, and left the bolt & puck off.
I printed Alex's advice and took a trip with the Fronty to the local MOT centre for a second opinion.
Their advice was as exactly as Alex stated.
Leaving the bolt & puck off would not fail an MOT, but would only give rise to an advisory, or to repair as Alex suggested. If competent enough, weld a metal puck in place, or carry on drilling the snapped bolt out & helicoil the captive bolt.
The testers own personal recommendation was 'leave it mate, I'll be too much hassle'
So thank you Alex for your suggestions, and :butt: to whoever sent you that PM. I found no mocking, or discrimination on your post, only very good advice which I followed. Just what this forum is intend for.
Re: Snapped bolt by cheekychick on Sat Apr 11, 2009 1:25 pm
:ggod post: :wink:
and glad you have sorted a way to fix it :D
Re: Snapped bolt by alex on Sat Apr 11, 2009 4:36 pm
No worries, if ever your round the midlands I can sort you a metal puck with threaded center. Just need to know the lift.
As for the other,,, takes more than that to wind me up :wink:
