Calmini lift anyone ?
Calmini lift anyone ? by Drift on Tue Mar 31, 2009 9:45 pm
Re: Calmini lift anyone ? by Retro Pedro on Tue Mar 31, 2009 9:55 pm
It does state 98-2003 therefore a B series.
Does anybody know if this set will be OK on a SWB A (2.8TD Sport N reg) or are they completely different.
Re: Calmini lift anyone ? by Drift on Tue Mar 31, 2009 10:02 pm
The only thing I would be concerned about is the rear shock mounts, just make sure they are the same, other than that it will fit.
I think the picture is just for illustration.
Re: Calmini lift anyone ? by Road Hog on Tue Mar 31, 2009 10:09 pm
If it is the same kit as the picture then it will all fit apart from the rear shocks (B series shown eye & post where A series are eye & eye),the radius arms are for B series only (the cranked one is top N/S to clear fuel tank) so will be surplus to your requirements (but I know somebody that would buy them off you :wink: .
Re: Calmini lift anyone ? by Trugga on Tue Mar 31, 2009 10:16 pm
That looks like the kit that was fitted to my 2.8
The only bits used are the front upper arms, bump stops, brake lines and shocks, at the rear the panhard rod relocation bracket, coils and brake bracket extenders - the rest can be thrown away.
The trailing arms don't fit, neither do the rear drop links (the 4x flat blue strips), neither does the replacement cross member fit - all for the B
Re: Calmini lift anyone ? by Trugga on Tue Mar 31, 2009 10:26 pm
£550 starting bid :shock:
I'm sure Specialist Leisure were doing them cheaper than that.
Re: Calmini lift anyone ? by Drift on Tue Mar 31, 2009 10:45 pm
And thats got a reserve on it :shock:
Re: Calmini lift anyone ? by stu on Wed Apr 01, 2009 10:45 am
seems a bit expensive.
