Frontera Technical Support • View topic - Welding a fuel tank
Welding a fuel tank
Welding a fuel tank by Trugga on Fri Mar 27, 2009 5:24 pm
After this last weekends laning, it is apparent that my petrol fuel tank is leaking.
It is not the standard Frontera fuel tank, but a smaller one fitted higher up between the chassis rails.
I've had a chat with Weave67 who is up for the welding/patching job, but we would be appreciative on any tips on how we should proceed.
I'm hopeful that the tank can be removed from the car. It can then be drained of remaining fuel (and stored safely) then the tank washed out with copious amounts of washing up liquid and a hose pipe, and then left to dry/evaporate for an hour or so before attempting any welding.
Any other thoughts ?
That is an earlier photo, with the area indicated now moist with petrol.
Re: Welding a fuel tank by Road Hog on Fri Mar 27, 2009 5:56 pm
Easy peasy lemon sqeezy,but only if you can get it off the car. :roll:
After removing from vehicle & draining fuel,ensure the tank has an open vent pipe,Support the filler tube so that it is over the exhaust pipe of another vehicle & run the engine for about 5 - 10 minutes or until the is no smell of petrol,this is quickest when a diesel is used to purge the tank. :wink:
The reasoning as it was explained to me many years & fuel tank repairs ago.Bit of basic schoolboy physics................ exhaust gas is Heavy & largely carbon monoxide ,so the concentrated heavy non combustable gas sinks in the tank thus forcing the lighter combustable petrol vapour up & out through the vent. :D
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 6:07 pm
Or weld it full of water, asuming the leak aint so bad as to contaminate the weld :wink: then drain and refill with petrol.
What material is the tank made from? I asume you did a magnet test etc to make sure its weldable.
Sounds like a fun job.
Re: Welding a fuel tank by weave67 on Fri Mar 27, 2009 6:08 pm
i was just gonna say that bernie :oops:
Re: Welding a fuel tank by farmer on Fri Mar 27, 2009 6:59 pm
a fire extinquiser,first aid kit and some one standing far away with a phone with 999 on speed dial.
farmer
Pita Troll
Modifications: none completely standered and keeping it that way
Re: Welding a fuel tank by Krusher on Fri Mar 27, 2009 7:12 pm
A 3 meter long welding gun :lol: :lol:
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 7:16 pm
TBH, It would be a big enough flash to give dave a new haircut, but its not a fire brigade jobby.
Re: Welding a fuel tank by weave67 on Fri Mar 27, 2009 7:20 pm
Re: Welding a fuel tank by gkcollard on Fri Mar 27, 2009 8:35 pm
A friend's advice is spot on, no Oxygen = no fire = :D
Boys don't grow up, the toys just get bigger and more expensive!
gkcollard
Modifications: Its a Brava, is that a mod? 2.5 TD (Non Intercooled) Izusu Lump.
Hunting lamp
x4 Front Spots with LED sides
Rear work lights
Rear pick up bed mounted winch (will pull skin off rice pudding so long is its not too thick a skin!)
Boost guage
Fuel Pump "Adjustments"
Turning ball
CB Radio and Roof mounted antena
CD player with I pod line & 6x9s
Forestry Commission dog box removal and 2x seat install
Rear tool storage box install
300watt 230v Inverter
Wired in Ipod, mobile and Blue tooth chargers
Aux Interior lighting
More once my overdraft recovers!
Re: Welding a fuel tank by Alchamist on Fri Mar 27, 2009 9:10 pm
Hmm ... It's a bit more worrying when you don't have those options, and have a Fuddy and an Alex waving an arc welding rod around your petrol tank, right next to the leaky filler pipe ... and they wondered why I kept taking steps backwards away from them ... :lol:
The second time, when Bobby was waving his rod around the back end of my car, I think I was almost hoping it did go up ... not to damage Bobby at all, but it might have improved my truck a bit! :twisted: :lol:
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Welding a fuel tank by Rich on Fri Mar 27, 2009 9:27 pm
this reminds me of when i was working in a garage and we had an old bedford ha van come in to have the fuel tank repaired my gaffa removed the tank drained it and left it for an hour or so
he then put the tank on the work bench and set about patching it
he had faced the filler neck towards himself when all of a sudden the was a might whooshing sound and him screaming in pain a very large flame had come shooting out of the filler neck and burnt him in the never regions burn though his overalls :shock: :shock: :shock: and singeing his bits
so be careful
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 9:29 pm
As an apprentice I was told to use gas to cut some old shock absorbers apart. The resulting fire ball left me somewhat sore even below several layers and a full face mask. Learnt that lesson, it may look dangerous, but I do take saftey seriously.
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 9:31 pm
Just a side note, have a good look as to why its popped the seam. If its just poor welding then fair enough, but if it looks like its had a bounce it may be worth looking into a bash plate for it. It is a little exposed.
Re: Welding a fuel tank by Drift on Fri Mar 27, 2009 9:34 pm
Angle iron down the seam :D
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 9:39 pm
Could be one way, maybe a few transverse straps too.
Re: Welding a fuel tank by Road Hog on Fri Mar 27, 2009 9:42 pm
There is the "other" technique,which I do not recommend.While it is quicker if it goes wrong will prove that adrenaline IS brown. :shock:
Re: Welding a fuel tank by Drift on Fri Mar 27, 2009 9:45 pm
Empty tank light match on long pole hover over tank outlet, leggit :shock:
Re: Welding a fuel tank by Road Hog on Fri Mar 27, 2009 10:10 pm
Re: Welding a fuel tank by alex on Fri Mar 27, 2009 10:41 pm
Have someone blow down a hose into it while burning the vent gasses :oops: just dont run out of blow :shock: or start suckin :?
Re: Welding a fuel tank by weave67 on Fri Mar 27, 2009 10:45 pm
we could do with somebody with a lot of wind,,,,,,,,,,,,,,,,,,,,now were did i put postfinders number :dance:
