Frontera Technical Support • View topic - Any Ideas ?????????????
Any Ideas ????????????? by frontydan on Thu Mar 05, 2009 11:10 pm
Hi All,
just out of interest does anyone know what i should ask for my truck???
I know i won't get back the cost of all the mods and the sale would not include the jack, waffle boards and possibly the tyres.
Just curious 'cos i can't seem to get the thought of a coiler out of my head at the moment, the fact that they are easier to lift makes them rather appealing.
So far this one has got a 2" suspension lift, 2" body lift and of course the chequer plated "pick up" rear end.
Thanks in advance for any input and if anyone might be interested please let me know.
Dan
Member number 4669
frontydan
Bill
Bill
Vehicle Name: The bus
Body lift, 2".
3" suspension lift.
Blue LED dash conversion.
Waffle boards x 2.
AVM Manual locking hubs.
De Catted..... 'Cos i can !!!
Stickers akimbo.
To Follow...........
Re: Any Ideas ????????????? by Drift on Thu Mar 05, 2009 11:15 pm
Top end £500 to £600 with tyres
Re: Any Ideas ????????????? by andysd1 on Fri Mar 06, 2009 12:26 am
if you want to and i mean this only if you are sure and really want to do this and you wont back out and are definite going to do it and are sure, you can swap for my 2.8 if you want to,
ops i mean the 2.3
Re: Any Ideas ????????????? by Sir-Doris on Fri Mar 06, 2009 12:41 am
As drift said, around £500 with tires. Modded cars never really make back what has been put into them unless they are something really special. particularly 4x4's.
Graphics and so on are also subjective to the potential buyers fashion sense and can put a lot of people off.
Re: Any Ideas ????????????? by gregster on Fri Mar 06, 2009 12:42 am
Easier to lift.....twaddle.....
Spring over axle conversion is what you need my friend....Will out articulate a coiler I reckon and not rear steer as much when tucked!
Afternoons work... :lol: :lol:
Re: Any Ideas ????????????? by jmc on Fri Mar 06, 2009 12:59 am
Gregster whats a spring over convertion please? thanks.
jmc
Re: Any Ideas ????????????? by Sir-Doris on Fri Mar 06, 2009 1:00 am
Its when the axle is mounted under the leaf springs instead of on top of them, its another 2 to 3 inches of lift easy.
Re: Any Ideas ????????????? by gregster on Fri Mar 06, 2009 1:11 am
Re: Any Ideas ????????????? by alex on Fri Mar 06, 2009 8:09 am
I'm with Greg on this one Dan.
One thing you will find is on either there will be some work to get the prop to articulate that far, it fouls on a chassis cross member it goes over. Will need moving or removing. One reason I went LWB.
Re: Any Ideas ????????????? by gregster on Fri Mar 06, 2009 10:57 pm
My SWB "A" yellow fronterror has SOA rear with no probs, no clearance issues whatsoever...was it a "B" that was hitting crossmembers?? :?
Re: Any Ideas ????????????? by Frontycustoms on Sat Mar 07, 2009 12:24 am
Soa all the way baby. :dance: :dance: :dance: Lets get doin some moddin then Dan man :lol: :lol: :lol: :lol:
Re: Any Ideas ????????????? by gregster on Sat Mar 07, 2009 1:28 am
I mIght be able to make up the axle blocks if you are not able....but they will need properly welding on :shock:
(no offense guys, but I don't know what level your welding skills/equipment are at)
I normally use 5mm ish wall rectangular box section....cut the axle radiuses into the faces with plasma cutter, and then weld the ends up, and cut hole for spring locating bolts. This then slots over the top of the axle and axle can be rotated slightly to be nicer to diff end prop uj before welding on.
If the blocks are kept to around the height of the VX blocks under the axle then the standard U bolts will go back in.
Be warned you will need a long pair of axle stands to do this as chassis gets a long way from the ground!! I use a forklift or telehandler but thats cos I'm lazy!
Let me know if you need any help....
Laters
Gregster
Re: Any Ideas ????????????? by bobbinsjob on Sat Mar 07, 2009 11:10 am
Where abouts are you Greg as I may need some help with Nemesis when i come to do the SOA on her
Re: Any Ideas ????????????? by gregster on Sat Mar 07, 2009 8:00 pm
Re: Any Ideas ????????????? by Frontycustoms on Sun Mar 08, 2009 12:09 am
Gregster u got pics of the soa conversion mate please. Dan can arc weld n I can mig weld so fittin the blocks wont be a problem mate :wink:
Re: Any Ideas ????????????? by gregster on Sun Mar 08, 2009 12:51 am
Re: Any Ideas ????????????? by alex on Sun Mar 08, 2009 2:21 pm
Sounds like a day of bashing with hammers :D Having seen some huge Yankee extensions I wonder if we can go Bigfoot?
Re: Any Ideas ????????????? by frontydan on Mon Mar 09, 2009 11:03 pm
Member number 4669
frontydan
Bill
Bill
Body lift, 2".
3" suspension lift.
Waffle boards x 2.
Stickers akimbo.
Re: Any Ideas ????????????? by Frontycustoms on Mon Mar 09, 2009 11:54 pm
Ya not far off with the lwb are ya Alex :lol:
Re: Any Ideas ????????????? by alex on Tue Mar 10, 2009 8:25 am
Still measuring the jobs to come in whole inches Mark :wink:
