Ok,
Finished work early tonight, so up for an early start to the springs.
Loosen the bottem bolt on both shocks, and the wheel nuts.
Jackup the car from the diff, axel stands under the axels, the further lift via 4" jack platform, axel stands now under the chaissis rails at full extension with 4" paltform as well, so all nice and high.
Remove the nut from bottom of the shocks, and slide off the left shock from the bolt.
Slide off right shock and find it hits the chassis mounting for the bar that goes behind the diff, (name unknown).
Try to undo the top bolt and no joy, so cant see how
to remove the shock bottom bit on the right hand side.
Also when trying to drop the axel to replace the left spring the bar above the axel fouls on the top of the tank thus reducing travel on that side.
So tomorrow I will try and get a spring compressor and try and compress the spring to get them out and repalce,
Unless any one else has any better ideas, Shocks are just over 2 years old and are es9000 so dont want to damage them during this procedure.
Help
