Very good as standard, however a good set of tyres will be your first wise investment, then if you want to lift, then a set of standard trooper springs for rear, wind the torsion bars up, and add some plus 2 inch shocks.
If you need some extra protection, fit some metal belly plates to replace the plastic ones.
Also have a look to see if you still have the stone gourd above the prop, (centre) if it is still there remove it, or you will need to remove later when it is bent against your prop and making a lot of noise after a few lanes.
