Frontera Technical Support • View topic - Show me a pic of your young bum....... per
Hi,
After a few lanning trips I am getting to the point of no more repair on my rear bumper, see below :butt:
and as such was wondering what others that done to their rear end ON THE FRONTERA :mrgreen: to get round this problem.
I was thinking along the lines of a door mounted number plate aka swb, and removing the bottom painted bit of the bumper and hopefully leaving the plastic checker board bit still as a step for the dogs to get in / out of.
Anybody got any pics of their rear end pref a 'B' :butt: :dance:
Also looking to get a 1.5" body lift and 2" susspension lift as well, so will I be able to do that sort of lift without needing brake pipe extensions and modding the gear levers or is it a case of try it and see>
Trev.
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: Show me a pic of your young bum....... per by Drift on Thu Feb 12, 2009 11:51 pm
I left the to bar cross beam on and ground the bar off, that gives a lot of protection, but I still bend the number plate and pop the number plate lights quite a lot :roll:
The body lift will bring the bumper well above the tow bar (if you have one fitted) when laning, I rem ove the detachable bit of the towbar which still leaves the heavy bracket which gives good protection to the bumper and I have moved the towing electrics to be mounted onto the bumper itself.
As for a 1 1/2" lift, you will not need to change the brake lines, but you may need to shave the gear stick channel and release the steering coupler bolt whislt lifting (remember to do it back up after)
Remember, the bumpers are attached to body and the chassis so will have to be removed and realligned
Fortunately, mine was like this when I got it:
I belive something similar is being done to a LWB though.
Never had a problem with my rear end :lol: :lol:
lotusfrontera
very nice was admiring your rear end the other week while i was waiting behind you at the lights
You should have papped your horn :wink:
lotusfrontera
black pt cruiser x reg trucks off road for a couple more weeks. better get back to topic :oops:
Ok Guys,
Struggling a bit now, Have tried to remove the rear bumper and have undone all the nuts and bolts I can find, but it still seems to be attached to the body work at the side, just behind the rear wheel.
I am trying to do a body lift and cant get the bumper off, nor can I access the last 2 "pucks" with it on. Anybody know how to get it off of a LWB B.
Trev
country_Est
Re: Show me a pic of your young bum....... per by Drift on Sat Feb 21, 2009 3:23 am
After a night out with the boys and my bum as a bit sore and looked like this,
Read a few posts shed a few pounds, (quite a few) and now look like this
country_Est
Re: Show me a pic of your young bum....... per by Drift on Mon Mar 16, 2009 1:10 am
Thats looking high now 8)
