Frontera Technical Support • View topic - Rear Light Guards Yes or No.
Rear Light Guards Yes or No. by Tiddles on Tue Feb 10, 2009 11:40 pm
I have a set of rear light guards to fit on my car but have had conflicting comments on them :?
Some say they are good and do protect the lights but others say thay are just fashion accesories that can damage the lightys espeshaling when laining :shock:
I had some on my Shogun but they bolted on to the bumber and you could knock down a wall with them :D
If I decide not to fit them is there a market for them on FOG?
Tiddles
Modifications: 2" lift
Nice gripy tyres :)
Re: Rear Light Guards Yes or No. by Sir-Doris on Tue Feb 10, 2009 11:45 pm
Depends on the light protector fittings and the construction of the light guards themselves. Most seem to have tabs that wrap around the light cluster and the original screws go through them.
Personally I have found mine to be more useful then not, they do stop branches etc. from springing back against the lenses.
However, they definitely wouldn't protect the lights if the whole car slid into a tree or wall etc but I very much doubt that any light guard would offer much protection against that.
Re: Rear Light Guards Yes or No. by Trugga on Tue Feb 10, 2009 11:46 pm
I've had rear light guards on my LWB for five or so years - lots of laning, playing and motorsport marshalling and not damage to report.
Re: Rear Light Guards Yes or No. by Drift on Tue Feb 10, 2009 11:48 pm
I like the look of them , for what its worth :D
Re: Rear Light Guards Yes or No. by Sir-Doris on Tue Feb 10, 2009 11:49 pm
By the way Im sure someone would have them if you decide not to fit them.
Re: Rear Light Guards Yes or No. by Drift on Tue Feb 10, 2009 11:50 pm
:D :lol:
Re: Rear Light Guards Yes or No. by boybilbo81 on Tue Feb 10, 2009 11:51 pm
I would say yes, I had some on my old SWB, and have been trying to get some for my LWB, but no luck yet!!! Great for laning. :dance:
Image Image
boybilbo81
Modifications: C75 Aluminium Expedition Roof Rack
Front Roof Lights
Rear Work Lamp
Roof Strobes front and rear
Bonnet deflector
2x 18mm Galvanised bow shackles on the front
Insa Turbo Traction Track Tyres
235/70/16
2x CB Radios
PA System
Planning:
2" Body Lift
2" Suspention Lift
Moddified Air intake (not Snorkel)
Re: Rear Light Guards Yes or No. by andysd1 on Tue Feb 10, 2009 11:52 pm
just acquired a full set of light guards front and rear, and lower ones for the swb, they will be going on soon heheheheheh
Re: Rear Light Guards Yes or No. by Krusher on Wed Feb 11, 2009 12:34 am
I think there just cosmetic dont fit bother.............. How much do you want for them :lol: :wink:
Re: Rear Light Guards Yes or No. by andysd1 on Wed Feb 11, 2009 12:39 am
Re: Rear Light Guards Yes or No. by Krusher on Wed Feb 11, 2009 12:41 am
Re: Rear Light Guards Yes or No. by woodwizzard on Wed Feb 11, 2009 10:41 am
If they have the tabs that fit behind the light unit a stout branch wedged in there will rip the whole lot of, depends what you do with you truck really.
Re: Rear Light Guards Yes or No. by Tiddles on Wed Feb 11, 2009 7:59 pm
It looks like they just screw on posably using the light fitting screws and dont apear to have tabs.
I only do laining and avoid serious off roading.
Tiddles
Nice gripy tyres :)
Re: Rear Light Guards Yes or No. by andysd1 on Wed Feb 11, 2009 8:30 pm
i have the stubs that fit between the guard and the light
Re: Rear Light Guards Yes or No. by Tiddles on Wed Feb 11, 2009 9:14 pm
Do I need stubs and will I need longer screws :?
Tiddles
Nice gripy tyres :)
Re: Rear Light Guards Yes or No. by Drift on Wed Feb 11, 2009 9:15 pm
Im pretty sure you will need longer screws.
Re: Rear Light Guards Yes or No. by Sir-Doris on Wed Feb 11, 2009 10:04 pm
I think the construction of the light guards has a part to play as well. I have flat guards which dont bend inwards but will bend up and down, they are only attached with metal tabs and have taken some stick from off roading abuse.
I suspect that tubular guards will be more likely to bend in towards the lens then mine.
Again though I stress that it depends on how hard you hit them and what with.
Re: Rear Light Guards Yes or No. by paul higgi on Wed Feb 11, 2009 10:35 pm
paul higgi
3" body lift
5;38 diffs front /rear
ARB compressor
Superwinch EPI 9
Revolution transfer gears
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Isuzu trooper rear axle
Isuzu trooper front axle
Safari snorkel / RHS SS25HF
Arches cut and welded
trooper transfer case housing
Hydraulic handbrake
AVM manual locking hubs
3" Flexi Arch Kit
Re: Rear Light Guards Yes or No. by Sir-Doris on Wed Feb 11, 2009 10:53 pm
Still getting conflicting reports I see ;-)
Re: Rear Light Guards Yes or No. by Tiddles on Thu Feb 12, 2009 8:28 pm
Tiddles
Nice gripy tyres :)
