Postby JEOH on Wed Oct 26, 2016 9:50 pm
Marion's sister called yesterday. One of her company's trucks has passend away. A 2006 Ford Transit dti with a big and expensive problem with the injectors.
As a coincidence, our plumber had a Opel Vivaro for sale. Gave him a Fall, an hour later the Transit was replaced.
Today it was my turn to pull off the company markings Form the Transit :lol:
Maybe it is still worth a few bucks.
Reminded me pulling off the advertising of the previous owner of Godzilla six years ago.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: GodZilla & Grünstreifen
Modifications: G o d Z i l l a :
lightbar 4 x"Hella Micro FF",
IRMSCHER bullbar Sidesteps,
add. 12VDC plugs,
DEFA heater 230V DC,
General Grabber AT2 235/70R16
just keep it rollin'
G R Ü N S T R E I F E N 1997:
BL 2.5 cm, roofrack scratch w cb,
stripped interior,
DEFA heater 230V DC + motorwarming
Nortenha MTK2 235/70 R16
Postby lee771 on Fri Nov 11, 2016 6:15 pm
Not today but last Saturday had the old girl cleaned by the guy that does all the cars at my Bros work. She came up really well.
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Postby Loneranger on Sun Nov 27, 2016 11:01 am
Replaced turbo and starter motor on my trooper.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Postby Fronterror on Sun Nov 27, 2016 5:14 pm
Replaced instrument cluster bulbs with blue leds :D
grangeforge.co.uk
@Grange_Forge
Fronterror
Postby RatCav on Sun Nov 27, 2016 9:41 pm
Fixed another set of wobbly front wheel bearings on a friends Bighorn. Doing it so often I have made a tool to make it easier. Seeing as I have never really welded before I was rather chuffed that a) it held together and b) it worked a treat. Used stuff I found lying around college and an old hub bearing nut.
No more mucking around with hammers, screwdrivers and spring gauges to get it right.
Postby robbie on Sun Nov 27, 2016 10:40 pm
Look good Neil . I used a bit of scaffolding tube and 2 bolts, and socket same as you
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Postby lee771 on Sun Dec 04, 2016 11:32 am
Did my first night time green Lane last night makes for completely different experience
lee771
33 12.5 15s
Postby JEOH on Sun Dec 04, 2016 11:45 pm
Les, this makes me jealous a bit...
Today, I took care of GodZilla's sunroof. Cleared the ice, cleaned the seals from dirt and leaves. Then I gave the rubber a little massage with kind of grease.
The installed the DEFA heater again and ran it for two hours - all dry again.
Returned yesterday from a two week trip to the coast and found the windscreen wet in the inside. As the Alfa is knocked down at the moment (no loading pressure, running slow and noisy) and will return in a week or so by ADAC support to get repaired at home I will need the Frontera after I returned the rental car.
Grünstreifen has no MOT at the moment and so I am running out of cars in a way... :axe:
Kind regards,
JEOH
add. 12VDC plugs,
stripped interior,
Postby jaybrian32 on Thu Dec 08, 2016 10:53 pm
Last weekend
http://share.photobucket.com/shareprofi ... d=MzUzODY=
Spent the best part of an houreffort jet washing the remnant of Korc out of the underside today.
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Postby gregster on Fri Dec 09, 2016 11:10 am
RatCav wrote:Fixed another set of wobbly front wheel bearings on a friends Bighorn. Doing it so often I have made a tool to make it easier. Seeing as I have never really welded before I was rather chuffed that a) it held together and b) it worked a treat. Used stuff I found lying around college and an old hub bearing nut.
Good stuff Neal....I trust that was an imperial socket that sacrificed itself...LOL
Postby RatCav on Fri Dec 09, 2016 5:38 pm
Yup .. 15/16 Imperial ;)
Made sure it wasn't one I might need for the P38 as well :D
Postby Sir-Doris on Sat Dec 31, 2016 11:53 am
Well it's been a while. Progress had stalled somewhat due to work and motivation.
So, new rear shocks fitted. Rough country N2.0.
All new fuel and brake lines on the rear, they had been an advisory for several years before being laid up so duly thought it was time to change them. Good job too, most of them cracked with slight wiggling.
Waxoiled everything.
New tires ordered. Insa turbo special track in my preferred size, 265/75/16
Rear fuel tank guard chopped and rewelded to sit higher up in the chassis to suit the body lift I did about 8 years ago.
So as far as I can tell I only have left:
Smallish hole in the nearside rear sill just before the wheel arch.
Sticking relays in the alarm/immobilizer unit. Indicators come on randomly if the battery is reconnected for 20 minutes or so.
Which leads me to... Does anyone know if there are batteries in the tectus alarm/immobilizer unit (under dash, behind glove boxheater control panel somewhere if memory serves) or if it just has relays that need changing?
Will post this in the relevant alarm section anyway.
Postby JEOH on Sat Dec 31, 2016 4:28 pm
Well - a few days ago I managed with a friend to sort out the exhaust of Grünstreifen (replaced by a new part) and to get some welding the rear part of the sides for passing it's MOT for the next two years.
This car works hard to get my personal award of the cheapest car ever competing with GodZilla. But to be honest it is difficult breaking something while standing around most of the time...
Kind regards,
JEOH
add. 12VDC plugs,
stripped interior,
Postby lee771 on Sat Jan 07, 2017 9:33 pm
Fitted land-rover arch extensions ready for mot
lee771
33 12.5 15s
Postby dave1966 on Sat Jan 07, 2017 11:21 pm
Washed the fronty, seeing as it's not been washed since we got back from our holiday.
My first Frontera (1993 2.4i LWB). viewtopic.php?f=46&t=27691&p=309004#p309004
Comments on my (1993 2.4i LWB). viewtopic.php?f=32&t=41426
My present Frontera (1999 2.2 DTI LWB). viewtopic.php?f=46&t=52970&p=568393#p568393
Comments on my (1999 2.2 DTI LWB). viewtopic.php?f=32&t=52971
R.I.P Sable!(2005 to 2013)
dave1966
Postby red5 on Mon Jan 09, 2017 1:47 pm
New front pads and discs, stripped and cleaned sliders. Blimey, working brakes :-)
red5
Some dentage.
Postby Sir-Doris on Sat Jan 14, 2017 2:31 am
Finally. Took the truck in for an mot on Friday.
Passed with one advisory. Passenger seat not fitted at time of test.
Only have one niggle (technically 2) left. Nearside electric windows aren't working. I changed the lift controller and the switch as I had spares. Nope, not that so it's either the leccy windows themselves or a wiring issue.
Also stuck on an old set of road tyres for the mot as the knobbly ones on it has perished (5 years of not moving will do that to a tyre).
I'll get a new set of muds when I've had the wheels powder coated and have some spare cash.
Just need to get the 2 2.5 props cut and welded to make a 1 piece prop, it seems none of the one piece props from other models are long enough to fit a 2.2i.
I may wash the 5 years of green off it later today.
Postby RatCav on Sat Jan 14, 2017 11:01 am
Well done Sir-Doris
Postby Sir-Doris on Sun Jan 22, 2017 11:04 pm
Fitted new handbrake cables and shoes.
Seeing as we picked up a new horsebox I figured Phi would like a handbrake lever which doesn't require having Lou Ferrigno in the passenger seat to release it.
Postby RatCav on Mon Jan 23, 2017 12:32 am
Awesome :D
