Frontera Technical Support • View topic - syphoning fuel
syphoning fuel
syphoning fuel by jellybaby on Sun Jan 11, 2009 8:58 pm
as my sport is standing and it has over half a tank of fuel in i want to syphon most off whats the best way.
Re: syphoning fuel by priestinthejeep on Sun Jan 11, 2009 9:10 pm
im nearly sure their is a anti syphonin gard i think best was is try get to 1st fule filter just at back wheel let pipe of at tak side with filler cap open should work
priestinthejeep
Re: syphoning fuel by Frontycustoms on Sun Jan 11, 2009 9:14 pm
Dave when u've done that turn the ignition on n let the fuel pump do it for ya mate. :wink:
Re: syphoning fuel by jellybaby on Sun Jan 11, 2009 9:21 pm
sounds like a good idea need to replace fuel filter anyway so that can be done at the same time :D
Re: syphoning fuel by Drift on Sun Jan 11, 2009 10:01 pm
Oh you battery and starter are going to love you :lol: :lol: :lol:
Re: syphoning fuel by jellybaby on Sun Jan 11, 2009 10:09 pm
ah well better than nothing
Re: syphoning fuel by Frontycustoms on Mon Jan 12, 2009 12:54 am
Dont even need to crank it over............turn ign on too stage 2 so u have dash lights n the pump goes into a kinda primer mode to build up pressure n since the pipe will be off there wont be any pressure so in theory it should keep pumpin :wink:
Re: syphoning fuel by Drift on Mon Jan 12, 2009 12:57 am
This guy has pinched fuel before :lol:
Re: syphoning fuel by Sir-Doris on Mon Jan 12, 2009 6:23 am
On a side note and for future reference the 2.2 pump only starts when you turn the key to stage 3 (to start the car) and continues running until you switch off the engine.
Re: syphoning fuel by FUDDY MUCKER on Mon Jan 12, 2009 8:44 am
Re: syphoning fuel by derbylad on Mon Jan 12, 2009 9:01 am
or you can do what i do and that is discoonect the fuel line from fuel filter and then get a bit more pipe and attach the it to fuel pump. then get to long bits off wire and a battery.then connect on side off the wire to the battery and the other side to the fuel pump wiring.then just let it drain.
derbylad
