screen washer jets
screen washer jets by hawk on Sat Jan 10, 2009 11:04 pm
recenlly had a problem with no water comming out of the jets on the bonnet on my 2003 2.2 olympus model found the problem tube had come off connector but on the underside of the jets on the bonnet their is an electrical connector for each jet with two wires in it the jets are standard vx does anyone know what they are for or do ..
olympus lwb 2003 2.2 dti
hawk
Modifications: uprated shocks & brakes
under sidestep lighting
Re: screen washer jets by frontydan on Sat Jan 10, 2009 11:14 pm
At a guess i would say that the wires are for the pimped up LED washers............... Don't use them 'cos you will look an :butt:
I say this 'cos when i sold my wifes truck to Frontycustoms the first thing he did was connect up the two wires and the LED's lit up...... i had it for 12 months and never looked atthe washer jets so from this i can say it is not obvious that you have the LED washers fitted, well i never knew anyways.
Hope this helps
Dan
Member number 4669
frontydan
Bill
Bill
Vehicle Name: The bus
Body lift, 2".
3" suspension lift.
Blue LED dash conversion.
Waffle boards x 2.
AVM Manual locking hubs.
De Catted..... 'Cos i can !!!
Stickers akimbo.
To Follow...........
Re: screen washer jets by nitromotor on Sat Jan 10, 2009 11:17 pm
Headed washer jets for the frosty mornings, thay are on the v6, and options on others
Re: screen washer jets by Krusher on Sat Jan 10, 2009 11:18 pm
The two wires on the washer jets I would assume are for the heating element within the jet to stop them freezing up in winter.
Re: screen washer jets by priestinthejeep on Sun Jan 11, 2009 1:27 am
how do the heated jets work are they constantly on or come on when start up??
priestinthejeep
Re: screen washer jets by andysd1 on Sun Jan 11, 2009 3:36 am
they come on on start up, and are only on for a minute or two
Re: screen washer jets by Sir-Doris on Sun Jan 11, 2009 6:59 am
As above, heater elements for washer jets.
Re: screen washer jets by weave67 on Sun Jan 11, 2009 9:03 am
your lucky i got nothing like that on trusty rusty :cry:
Users browsing this forum: No registered users and 58 guests
