ECU warnings and ODB 2 cables
ECU warnings and ODB 2 cables by jamesyb on Mon Jan 05, 2009 11:33 am
I've been having the engine management light come up on my 2001 Fronty B DTi for a couple of months now and, whilst it is annoying, it goes away after a while. However, I'd like to find out what is causing it and there lies the question...
Is it worth going for something like a handheld reader (fleabay listed for about 40 notes for a basic one), or using laptop and software with just the EODB/ODB2 cable? I have the Vx COSIDS software somewhere that I can sling on a laptop and I seem to remember a section in there about Tech 2, but does anyone here use this to diagnose the generic engine light?
Also if the latter is the way to go, should I go for fancy software that allows me to do more stuff like ECU remapping, or have I just watched The Fast & The Furious too many times?
Cheers,
James
p.s. is feabay the best place to get the cable, or is there a better place?
2000 2.2 Ecotec Diesel LWB. The "Limited" one with t'leather and A/C - Oh yeah!
jamesyb
Re: ECU warnings and ODB 2 cables by ukcobra on Mon Jan 05, 2009 11:48 am
I do not think the Frontera has the capability to be re-tuned . I've been to a few performance outfits that re-map ECUs as their business, and it requires skill, training and experience to do it successfully. Typically it involves flashing a new chip and replacing the one you have currently, this way you can go back to a factory setup really quickly and cheaply, should you need to.
Mark
ukcobra
Modifications: 96 2.0 S SWB
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: ECU warnings and ODB 2 cables by jamesyb on Mon Jan 05, 2009 12:47 pm
Righto, that's that out of the window then. Not a problem.
What about reading the ECU codes though? Have you got any recommendations on whether the COSIDS program can read them just using a cable, or whether I should get a handheld reader?
jamesyb
Re: ECU warnings and ODB 2 cables by nigelbread on Mon Jan 05, 2009 1:03 pm
Hi read this post -
viewtopic.php?f=20&t=21489
the reader I have reads with engine both ignition on and/or running and works well.
nigelbread
Modifications: +
Re: ECU warnings and ODB 2 cables by jamesyb on Mon Jan 05, 2009 1:09 pm
Excellent! I guess now the only thing I need to find out now is whether or not my 2.2 DTi is ODB2 compliant or not...
Any takers? (W plate if that helps)
jamesyb
Re: ECU warnings and ODB 2 cables by bobbinsjob on Mon Jan 05, 2009 5:20 pm
yes it is
