Frontera Technical Support • View topic - MOT LOOMING !!
MOT LOOMING !!
MOT LOOMING !! by jonno612 on Sat Jan 03, 2009 8:20 am
mot is due to run out on the 19th, so not long left - if anyone is a mechanic / has recently mot'd their fronty im looking for any rough idea of how much its going to cost to get sorted out?!?
slight oil leak
oil needs changed anyway
gearbox or diff fluid needs refilling / replacing - making whirring whiny noise at low speed
brakes are all squeaky - hopefully just pads
driver side windscreen wiper u/s
tyres not w whole load of tread left - will be at least an advisory :(
any ballpark figure would be appreciated so i can go and beg the bank for pennies
hoping that i wont end up like this --> :butt: with a dodgy moneygrabbing mechanic behind me lol - i know theres a recession on but i hate people taking the proverbial wee-wees
cheers,
jonno
a Frontera is a workhorse, not a lifestlye choice
jonno612
Modifications: none yet - WANTED - roof bars / cage with spots, spots for my ally bullbars, BIG offroad tyres, body lift, snorkel, rubber bootlinings and mats, seatcovers.............
Re: MOT LOOMING !! by Alchamist on Sat Jan 03, 2009 8:36 am
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: MOT LOOMING !! by jonno612 on Sat Jan 03, 2009 1:01 pm
thanks for the info Jay :ggod post: - quick update :
oil is dripping from the bottom of the sump by the look of it - might be that i overfilled the oil hen it was low last time and the excess has to go somewhere.
as for the u/s wiper its somewhere in the electrics or mechanism - i broke it de-icing the car, or rather not de-icing it properly before flicking the wipers on :oops:
cheers,
jonno
jonno612
Re: MOT LOOMING !! by philmotman on Sat Jan 03, 2009 4:31 pm
sounds like the wiper arm has come loose just tighten the 13mm nut at the bottom of the wiper arm theres proberbly a cover/cap over it.as for the oil leak this is not an mot fail just advice.from your list the only thing that can fail is the wiper(easy fix)and the tyres?
hope this helps.
also if you need some tyres i have some. set of 4 federal couragia s/u 255/65/r16 these are rotational tyres they all have at least 6mm of tread on them. got pics if required, £85 for all four.
phil
philmotman
Re: MOT LOOMING !! by jonno612 on Sun Jan 04, 2009 7:34 am
thanks phil - you have pm
jonno612
