Frontera Technical Support • View topic - soldering
soldering
soldering by woodwizzard on Fri Dec 12, 2008 4:04 pm
Having not done any soldering can anyone tell me if this kit is suitable for doing connections on my winch power cable and general electrical bits and bobs http://cgi.ebay.co.uk/DRAPER-71420-100W ... 240%3A1318
Re: soldering by Sparky Martin on Fri Dec 12, 2008 4:21 pm
Hi woodwizard
I am an electronics engineer with 45 years experience in soldering, I live in Trowbridge Wiltshire
if you can get here I can solder it, no problem.
Sparky Martin
Modifications: None, its as good as it came of the production line.
Re: soldering by woodwizzard on Fri Dec 12, 2008 4:26 pm
Thanks for that Martin :D I will have other little jobs to do so would look to buy a little kit anyway, don't need anything flash just good enough to do a little bit of DIY soldering. Do you think the kit will be ok?
Re: soldering by tfb on Fri Dec 12, 2008 4:52 pm
A bit more expensive, but I'd go for something like http://www.screwfix.com/prods/52302/Ele ... Iron-PS100 .The advantage with gas is a quick warm up time and no power cords!
Regards
TFB
tfb
Modifications: F reg 2.5TD LWB Pajero
235/85/16 Insa Turbo Traction Track tyres
Twin tanked to run on used veg oil
duct tape over the rust holes in the wings to get it through the MOT
Re: soldering by Sparky Martin on Fri Dec 12, 2008 5:41 pm
Hi again Woodwizzard
Either soldering iron will do, both have advantages and disadvantages,
if you could afford it I would get both, if you are considering soldering very
large cables i.e. 4mm or above you will require even a bigger soldering iron
or a small blow torch.
If you feel the need I am prepared to teach (advise) you on how to solder.
Please remember that if you are using a lead based solder that lead is a poison,
so take precautions.
Do not inhale the fumes and wash your hands after wards.
Sparky Martin
Re: soldering by bobbinsjob on Fri Dec 12, 2008 5:46 pm
:ggod post:
Re: soldering by meooo on Fri Dec 12, 2008 5:56 pm
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
Re: soldering by woodwizzard on Fri Dec 12, 2008 7:28 pm
The first job will be to cut the livewire to the winch so I can install an isolator switch, so yes, the cable is pretty beefy. I also need to put a decent connector on the live to my alternater, so again quite thick wire. After that it will only see the light of day occassionaly.
Re: soldering by jmc on Sat Dec 13, 2008 12:01 am
I expect you know but my old metalwork master used to say,in reference to soldering, "get it mechanically clean and chemically clean".I always go overboard with getting the work clean with a file or emery cloth ,try not too touch it, and use solder with flux in the core and put flux on as well.I use an oxyacetelene torch with a very small nozzle as I can be certain of getting it hot ( I have always stuggled with soldering irons) and melting the solder properly but this may be awkward on a vehicle. The stuff I do is nearly always on a bench and to be honest I hardly ever solder. If you do go for a soldering iron get the biggest and hottest there is nothing worse than having to reclean and resolder a joint.Give me welding any day.
jmc
Re: soldering by weave67 on Sat Dec 13, 2008 8:50 am
ive been a welder for 20 years now welding things from j.c.b buckets, to lamposts,and i consider myself to be dam good at it ,,,,but soldering beats me everytime, :oops: i always end up getting the insolation tape out :roll:
Re: soldering by jmc on Sat Dec 13, 2008 8:25 pm
My brothers a goldsmith, so if I can possibly wangle it I get him to do soldering for me.I find the tactic of standing around with the bits looking helpless does the trick. Welding's great .
jmc
