Frontera Technical Support • View topic - Check YOUR Nuts!
Check YOUR Nuts!
Check YOUR Nuts! by Sir-Doris on Sun Nov 30, 2008 8:01 pm
And no Im not talking about testicles.
While out on the laning trip yesterday I was hearing a funny clunking sound. At the first lane I stopped and had a look but couldnt see anything amiss. I put it down to the new tires rubbing at lock and/or suspension travel.
As I have a loose wire on the starter motor I have reason to get under the car sometimes to get it started and today when I was under the car I noticed that 2 of the lower ball joint nuts had come off and 2 of the bolts had escaped. On both the remaining bolts the nuts had loosened.
I shudder to think what might have happened had the remaining 2 nuts come away.
It must have been when the diff was dropped that the bolts weren't tightened up properly. Unfortunately it was the side that I tightened so I cant blame anyone else but myself.
So... In conclusion: CHECK YOUR NUTS! Then CHECK EM AGAIN!
Re: Check YOUR Nuts! by Roo on Sun Nov 30, 2008 8:38 pm
Re: Check YOUR Nuts! by Drift on Sun Nov 30, 2008 8:47 pm
Glad you found it, get some nylolock nuts, put two on sure to be sure :wink:
Re: Check YOUR Nuts! by perfectprincess on Sun Nov 30, 2008 9:15 pm
well i did think what i might find Doris with a title like that :D good post glad you ok
perfectprincess
Frontera Goddess
Frontera Goddess
Re: Check YOUR Nuts! by alex on Mon Dec 01, 2008 6:08 pm
:oops:
Which side? the ones I did or the ones you did?
Re: Check YOUR Nuts! by Sir-Doris on Mon Dec 01, 2008 6:15 pm
Re: Check YOUR Nuts! by FUDDY MUCKER on Mon Dec 01, 2008 7:48 pm
Just a quick point to anyone who has changed or modified any componant on either there steering or suspenstion ........
DO NOT TIGHTEN NUTS AND BOLTS UP TO THE CORRECT TORQUE UNTIL THE VEHICLE IS LOWERED TO THE GROUND AND IS RESTING ON THE VEHICLES FULL WEIGHT
As Trugga found out when he nearly lost his rear shackle. :shock:
Re: Check YOUR Nuts! by Sir-Doris on Mon Dec 01, 2008 8:29 pm
Yup, thats stated several times in the Haynes manual where suspension is concerned.
Re: Check YOUR Nuts! by barryc28 on Mon Dec 01, 2008 10:07 pm
Fronty2
2.8tdi n plate swb
white
flappy paddles removed
Es9000 +2 shockers
barryc28
Re: Check YOUR Nuts! by alex on Tue Dec 02, 2008 3:09 pm
:D
Cheers bud, I gave the pas side a few gut pulls on the big bar, never trust a wizzer, ask Goldfinder.
Re: Check YOUR Nuts! by Sir-Doris on Tue Dec 02, 2008 6:01 pm
When I did all the balljoints last time I used the air gun on em. Still no harm done (touching wood) and new bolts on the way.
Re: Check YOUR Nuts! by yaki on Tue Dec 02, 2008 7:32 pm
Been there done that and got a degree in it :lol: :lol:
After changing the front arms on mine 2 months down the line it started clonking from the front, checked and the bolts holding the fulcrum pin to the chassis had worked loose :roll:
After that I gave them all a tweak to make sure they were ok and then last week it started pulling to the left while driving and then to the right under braking :?
Had a shifty and the bl***y top suspension arm bush was out and resting on the chassis :oops: :oops:
I must be losing it :roll: :roll:
So now I am ultra paranoid, check, check, check again and then check a month later and don't ever stop checking :!: :!:
Re: Check YOUR Nuts! by Sir-Doris on Tue Dec 02, 2008 7:44 pm
I surprised myself as well as Im normally pretty good at that sort of thing. Must have been the early start, I was pretty knackered when we were finishing up.
Timing belt and sort out the loose wire on the starter tomorrow as well as check/tighten the suspension bolts.
Re: Check YOUR Nuts! by yaki on Tue Dec 02, 2008 8:05 pm
Re: Check YOUR Nuts! by Sir-Doris on Tue Dec 02, 2008 8:11 pm
Im hoping I dont have a 'where does this go' moment. Pretty straightforward changing the belt and idlers on the 2.2
Re: Check YOUR Nuts! by yaki on Tue Dec 02, 2008 10:55 pm
Changed the water pump on a 2.2 Frontera, there was about 7 days between stripping it down and putting it back together, took a few goes before the timing belt went the right way round the pulleys :lol: :lol:
There's a nice little tension indicator which is a great help when doing the belt
Re: Check YOUR Nuts! by Sir-Doris on Tue Dec 02, 2008 11:06 pm
The timing belt box (Gates) has a nice neat diagram on it of how to route the belt.
