Frontera Technical Support • View topic - 195/80 R15
195/80 R15
195/80 R15 by Fronty81 on Sun Nov 30, 2008 5:52 pm
Chaps.
Will the above tyres sizes fit a standard Frontera B Series?
I just need bigger tyres.. fed up of turning back from lanes around here due to large ruts I can't traverse.
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: 195/80 R15 by FUDDY MUCKER on Sun Nov 30, 2008 6:00 pm
Re: 195/80 R15 by Fronty81 on Sun Nov 30, 2008 6:08 pm
Just these were going cheap.
It's the ground clearence I'm after.. not fussed about the width of them.. I'd rather they cut through the mud.
and would 31's fit a Standard B Series?
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: 195/80 R15 by Sir-Doris on Sun Nov 30, 2008 7:30 pm
Re: 195/80 R15 by Fronty81 on Sun Nov 30, 2008 8:03 pm
Cool Beanz! :D :D :D :D
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: 195/80 R15 by bobbinsjob on Mon Dec 01, 2008 5:15 pm
31"s just fit on a standard B depending on the state of your suspension. If it has sagged a bit, you may find you have to fettle the arches slightly, A friend did a thread on how to "adjust the arches on a B" somewhere. Either way, you WILL have to remove the mudflaps or the tyres will do it for you.
195/80/15 will actually reduce your ground clearance
Re: 195/80 R15 by Fronty81 on Tue Dec 02, 2008 12:14 pm
IT'S NOT A JEEP!!
Fronty81
2" Lift
