Frontera Technical Support • View topic - Forum updates
Forum updates
Forum updates by Rich on Sat Nov 15, 2008 1:06 am
you may have noticed by now the forum as gone though a few changes can we please have some feed back as to what you think about the changes
Re: Forum updates by andysd1 on Sat Nov 15, 2008 1:11 am
no :wink:
Re: Forum updates by Rich on Sat Nov 15, 2008 1:14 am
ok :butt: :butt:
Re: Forum updates by nitromotor on Sat Nov 15, 2008 1:17 am
Its nice to have a this new landing page from the www.fronteraowners.co.uk, just need to make the forum links a larger and more noticeable element.
Re: Forum updates by andysd1 on Sat Nov 15, 2008 1:25 am
all looking fine from my end, well done one and all
Re: Forum updates by bobbinsjob on Sat Nov 15, 2008 8:07 am
well done to all concerned. we need to get more "How to's" on there
Re: Forum updates by weave67 on Sat Nov 15, 2008 8:08 am
yeah and i am loving FOG t,v well done to all involved :D
Re: Forum updates by Trugga on Sat Nov 15, 2008 12:47 pm
Re: Forum updates by bobbinsjob on Sat Nov 15, 2008 3:34 pm
speaking from a personal note, "How to's" on:
2.2 diesel 99>
Changing diesel leak off pipes
Changing fuel filter
Bleeding fuel system
Changing CHG
I'll have a trawl for the threads on how to do the dash solder thingy and the heated wing mirror mod and the cruise control conversion
Re: Forum updates by bobbinsjob on Sat Nov 15, 2008 4:02 pm
here's one, originally posted by Yorkie on 31st May 2007 in this thread...viewtopic.php?f=50&t=2152&st=0&sk=t&sd=a it's a massive thread so i just took the "how to do it" from there
":D well i decided to bite the bullet and do the solder fix :D now as i said i am mr thicko when it comes to stuff like this :lol: :oops:
1. i took out the 4 screws that hold in the facia ....... 2 by the speedo cocks on the underside of the dash ......... and 1 either side of the steering wheel behind the lower trim
2. once the facia is off the speedo cluster is held in by 4 screws you can then pull the speedo out a bit so you can disconnect the 3 cables
3. once you have the unit out you can remove the black panel that surrounds the speedo which also holds the perpex cover
4. then its onto the needles at first it seems the little buggers dont want to come off but a bit of prising with my fingers and a bit of :evil: and they came off luckily without taking the pins with them :D
5. now you can peel off the speedo black cover
6.i then removed the clear plastic cover this just pops off
7. now prise the board out by pushing back the little clips and there was 1 torx screw to take out .... also if you turn the thing over you will see in the corner a little square that a bit of the membrane goes into and there are a couple of bits of metal to bend back and now the board will pop out
8. i had a look with a magnifying glass and couldnt see anything wrong except at the top of the board the ten connecters looked at bit dodgy so i ran my solder over them ............. i didnt bother with anywhere else as it all looked a bit scarey :lol:
9. fitted it all back in and ............................... 8) 8) it works"
Re: Forum updates by bobbinsjob on Sat Nov 15, 2008 4:09 pm
Here is the one by Andyvee about doing the heated wing mirror fix, now emerging as a common problem on the B series
viewtopic.php?f=7&t=20643&p=233835#p233835
Re: Forum updates by bobbinsjob on Sat Nov 15, 2008 4:13 pm
cruise control conversion is just plug and play, so not needed
Re: Forum updates by Alchamist on Sun Nov 16, 2008 10:21 am
The dashboard fix is already on there (under known problems) ;)
Ian .. want to be a wiki author? :lol:
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Forum updates by bobbinsjob on Sun Nov 16, 2008 11:09 am
you'd have to show me how to work it :roll:
