Frontera Technical Support • View topic - 2nd time grrrr!!!!
2nd time grrrr!!!!
2nd time grrrr!!!! by b19sin on Fri Nov 14, 2008 2:27 am
i have just spent 100 quid on having my windows done after being told it was a write off and it went to the garage on wednesday to have its wheel bearing done but i had a phone call saying that they were having trouble with it so it had to stay in over night. had a call on thursday saying i could fetch it BUT is not fixed they couldn't split the half so for the second time its not repairable.
i think i mite have to give up with the fronty and let it go. if they cant do it iv got no chance, i really dont want to let it go as i have put a lot of money into it already with other parts (and i love it) but i cant see any other options HELP!!!!! :cry:
b19sin
Modifications: roof rack
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
boot full of tools & equipment (eg spade, hand winch)
Re: 2nd time grrrr!!!! by Drift on Fri Nov 14, 2008 2:29 am
Is it that they cant get the sleeve from the stub axle off the inner bearing ?
Re: 2nd time grrrr!!!! by b19sin on Fri Nov 14, 2008 2:38 am
they couldn't pull the half out at all, they said it had welded it self up
b19sin
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
Re: 2nd time grrrr!!!! by andysd1 on Fri Nov 14, 2008 2:46 am
Re: 2nd time grrrr!!!! by Sir-Doris on Fri Nov 14, 2008 2:47 am
I sense an angle grinder moment coming on ;-)
I believe Trugga had a similar problem recently with the bearing race welding itself to the stub axle, he ground it down as far as I remember. failing that heat will get it off, or better yet, another garage that knows about such things.
Re: 2nd time grrrr!!!! by Sir-Doris on Fri Nov 14, 2008 2:48 am
Or as above, if its the rear wheel bearing you need the bearinator!
Re: 2nd time grrrr!!!! by Drift on Fri Nov 14, 2008 2:49 am
Yes that sounds like what happened to mine, we ( Tim Bumptj) came across the dead inner bearing while changing the ball joints.
The inner bearing had in by the look of it welded its self to the drive shaft, we hammered and swore rather a lot, it didnt move, we heated it ( even though it was the one day this year it touched the 80's ) shock and unlock .. nothing, we didnt have a grinder or dremmel to hand, very careful use of these would have got it off, we just used a chisel and persevered in the end it came off, it is doable and the garage should have the tools do do the job.
We would have got it off easy with either more intense heat or careful use of a grinder.
Oh yer mime was the front, berinator kills the rear :twisted:
Re: 2nd time grrrr!!!! by weave67 on Fri Nov 14, 2008 6:38 am
bearinator 2 is available for a week if you need it :wink:
Re: 2nd time grrrr!!!! by barryc28 on Fri Nov 14, 2008 10:42 pm
careful touch of oxy acetalyne will have it off in no time, or as i call it "The Hot Spanner"
Fronty2
2.8tdi n plate swb
white
flappy paddles removed
Es9000 +2 shockers
barryc28
Re: 2nd time grrrr!!!! by b19sin on Sat Nov 15, 2008 1:05 pm
i dont have use of any heat! im thinking just change the axle
b19sin
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
Re: 2nd time grrrr!!!! by Drift on Sat Nov 15, 2008 5:28 pm
Is it front or rear ?
Re: 2nd time grrrr!!!! by b19sin on Sat Nov 15, 2008 6:32 pm
rear
b19sin
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
Re: 2nd time grrrr!!!! by andysd1 on Sat Nov 15, 2008 6:40 pm
trust me when i say the bearantor will remove it
if it dont it will turn the world once while trying
Re: 2nd time grrrr!!!! by Drift on Sat Nov 15, 2008 7:46 pm
Like Andy says use the bearinator might be worth a cheap gas torch from B&Q to help it along, should only cost a tenner to get it off. :wink:
Re: 2nd time grrrr!!!! by barryc28 on Sat Nov 15, 2008 11:21 pm
I've got a rear axle for a 2.3 if you need one
its a 4.56 ratio
Fronty2
2.8tdi n plate swb
white
Es9000 +2 shockers
barryc28
Re: 2nd time grrrr!!!! by weave67 on Sat Nov 15, 2008 11:22 pm
its ready and waiting :wink:
