Modified Throttle Body.
Modified Throttle Body. by Sir-Doris on Thu Nov 06, 2008 2:36 am
For some peculiar reason I ended up with a modified throttle body for the car some time back. being a tinkering sorta of chap I decided to fettle it a bit to kill a couple of hours.
Kind of hard to see in the pics but I have thinned the bar that holds the butterfly plate which should allow some more air in. I was going to change the screws holding the butterfly in for some countersunk ones which in theory should create a little less air turbulence but then I couldnt find and suitable screws (machine thread) in my box of bits. In the meantime I have countersunk the holes and will change the screws at a later date.
The butterfly itself is made of aluminium and I sharpened the edges of the plate with the tailing edge of the plate having a more curved shape to better enable the air to pass over it at part throttle.
Inside the body itself I flattened out the bumps and ridges.
Initial findings after fitting:
Car appears to have a very slight torque increase when moving off from low revs.
Engine seems to rev a bit more freely when you stomp on the gas from idling with little or no hesitation now.
I havent been on a long enough drive to see if anything else has changed yet but will report back.
Overall not a bad way to spend a couple of hours in front of the telly with a dremel.
Re: Modified Throttle Body. by Road Hog on Thu Nov 06, 2008 2:51 am
Phil,with the underside of the butterfly spindle that skinny,you should really centrepunch the screws to prevent them vibrating out. :wink:
Re: Modified Throttle Body. by Sir-Doris on Thu Nov 06, 2008 4:32 am
I tightened em up with some loctite. They aint going anywhere in a hurry :wink:
Unfortunately I took the metal off the wrong side of the spindle before I realised. DOH! Oh well, at the very least I have a spare. :D I sense a MK 2 coming on :wink:
