air ratchet
air ratchet by jellybaby on Sun Nov 02, 2008 9:01 pm
i some how have managed to jam my air ratchet does any body know how easy they are to strip down see if i can fix it
Re: air ratchet by alex on Sun Nov 02, 2008 9:06 pm
I saw the post after you stripped the brakes :lol:
Re: air ratchet by Frontycustoms on Sun Nov 02, 2008 9:08 pm
Just take it apart n see what happens, thats what i would do :lol:
Re: air ratchet by nitromotor on Sun Nov 02, 2008 9:09 pm
always lube your tool, before and after use or thay will not last!
as a first aid messure spray some wd in for a soak.
Dont forget to always use Cengar green oil or simler air line lube :D
Re: air ratchet by jellybaby on Sun Nov 02, 2008 9:50 pm
i always lube my tool :lol: :lol: :lol:
Re: air ratchet by Sir-Doris on Sun Nov 02, 2008 11:21 pm
they strip down easy enough. you can buy a gadget that goes inline between the tool and the compressor, this removes moisture from the air and lubricates the tool automatically with oil as you use it.
Re: air ratchet by jellybaby on Mon Nov 03, 2008 6:12 pm
ah i've got one of them very use full its still in the box i just put a few drops of oil in the oil hole every time i use it. i would like one of the pull out extendabul hoses on a reel when money allows.
