Fronty's now o.k
• Page 1 of 1
Fronty's now o.kChanged the MAF sensor tonight and all well. Could'nt believe it would make all that differance.
Re: Fronty's now o.kWell done, happy u got it sorted
Man who walk around with hands in pockets feel cocky all day !!!!!!!! Member 5876
Re: Fronty's now o.ki would tint the side windows as well
then when pump packs up from bio deisel folks wont see your blush's for not listening to there advice on useing it
Re: Fronty's now o.kThe B's dash has ALWAYS been a problem. Mostly the speedo does move at all.... try resetting the milage, or turning on the headlamps... this sometimes work.
Failing that you can remove the clocks, it's not a difficult job from what I can recall people saying. I've just left mine as I'm a lazy arse, and sometimes it works, sometimes it does't.. infact I might set about doing it today after I've done the CV Boot Gaiters.... Cheers. Matt Rolling Thunder, "Wagons Role".
IT'S NOT A JEEP!! ![]()
Re: Fronty's now o.kahhh the joys of frontera ownership
Long Live,Trusty Rusty ![]()
Re: Fronty's now o.kRolling Thunder, "Wagons Role".
Re: Fronty's now o.koh yes i did my rear bearing ,next thing i know, the propshaft u j went ,done that now the center bearing has started moaning, you gotta laugh
Re: Fronty's now o.kTurned the ignition on and off while tapping the glass near the clock, that knocked it down to were it should be!! So it is on it's way.
Re: Fronty's now o.kI could be wrong, but i think i've read about a fix on here for those dash clocks. I'll try n find it for ya................ unless Bernie beats me to it as usual
Re: Fronty's now o.kDid it again this morning, but if i turn the ignition on and off about 10 times, it drops down gradually, i'v read about soldering the back somehow.
Re: Fronty's now o.kSticking part way I think is a stepper motor fault .
Re: Fronty's now o.kIt is the motor that turns the speedo needle,it is a instrument panel out & stripdown job.
There is an exchange service http://www.bba-reman.com/catalogue/Deta ... oduct=1272 if you decide to go this route some feedback on the service etc would be appreciated.
• Page 1 of 1
Who is onlineUsers browsing this forum: No registered users and 5 guests | ||
