Shaky Drivers Side Mirror
Shaky Drivers Side Mirror by ukcobra on Sun Oct 19, 2008 9:51 pm
My drivers side door mirror shakes at speed, meaning it's quite hard to use the glass to see what's in my blind spot etc.
Before I take it apart, any tips as to how I can rectify this ?
The electric connections and heated element are working fine. It appears to be the main body is a little loose. Can it be tightened ?
Mark
ukcobra
Modifications: 96 2.0 S SWB
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: Shaky Drivers Side Mirror by Drift on Sun Oct 19, 2008 9:54 pm
Im prety sure it can using the screw mounting on the inside under the cover.
Re: Shaky Drivers Side Mirror by bobbinsjob on Sun Oct 19, 2008 9:57 pm
that is correct. carefully prize off the plastic cover and there should be 3 screws holding the mirror on, just nip them up but dont over tighten as they screw into plastic thread
Re: Shaky Drivers Side Mirror by ukcobra on Sun Oct 19, 2008 10:02 pm
Thanks, I'll give it a shot later this week.
regards
Mark
ukcobra
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: Shaky Drivers Side Mirror by Sir-Doris on Mon Oct 20, 2008 6:10 pm
As above but another thing to check and probably more common then the 3 screws holding the mirror to the door is... If you carefully pop the mirror glass off you will see 2 more screws holding the mirror body to the hinge that attaches to the door. Its been ages since I tightened mine up but I think they might be star drive screws. This cured the shaking for me. A little dab of superglue on the heads to stop them coming undone again helps as well. Being careful of course not to get glue in the actual screw head.
Re: Shaky Drivers Side Mirror by ukcobra on Mon Oct 20, 2008 6:13 pm
This sounds more like my symptoms.
Any recommendations how to get the glass out without breaking it ?
ukcobra
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: Shaky Drivers Side Mirror by Sir-Doris on Mon Oct 20, 2008 6:29 pm
take a large flat screwdriver or a smallish paint scraper, place it between the glass and mirror body and carefully prise it off, it will pop off and is held on with 4 (i think) ball clips. There are a couple of wires as well that are for the heated mirrors. Be careful when putting it back on though as its easier to crack the glass when pressing it back into the sockets then it is taking it out. Firm even pressure all round and dont force it.
Re: Shaky Drivers Side Mirror by bobbinsjob on Mon Oct 20, 2008 10:33 pm
when putting it back, put a bit of vaseline on your balls. If that dont work, put some on the ones on the mirror :lol: :lol: :roll:
Re: Shaky Drivers Side Mirror by ukcobra on Mon Oct 20, 2008 10:46 pm
I knew something like that was going to get mentioned :shock: :lol:
ukcobra
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: Shaky Drivers Side Mirror by bobbinsjob on Mon Oct 20, 2008 11:58 pm
that's meImage
