Frontera Technical Support • View topic - Engine Swap
Engine Swap
Engine Swap by Tiddles on Thu Oct 02, 2008 10:10 pm
I am thinking of maybe replacing the engine in my 2.4 although here is nothing wrong with the engine.
I am told that the 2.8 will drop right in so what to know if this possible as I thought the bell housing and bulk heads where different.
Also what other engines are available?
Tiddles.
Tiddles
Modifications: 2" lift
Nice gripy tyres :)
Re: Engine Swap by Drift on Thu Oct 02, 2008 10:16 pm
For 2.8 to go in you need the gear box as well and the rear prop as its a single prop, I think the 2.4 has a two piece prop.
The bulkhead shouldnt be a problem though.
Re: Engine Swap by Tiddles on Fri Oct 03, 2008 9:07 pm
Ok what other engines options are there?
Will the 2.3 fit?
Tiddles
Nice gripy tyres :)
Re: Engine Swap by Drift on Fri Oct 03, 2008 9:22 pm
Im pretty sure that will as they have the same bottom end as the 2.4, but I dont think it would be worth the risk if you 2.4 is running good, personally I wouldnt swap as there wouldnt be much gain if any, and the new engine could be worse than the good one your replacing.
Re: Engine Swap by Road Hog on Fri Oct 03, 2008 10:00 pm
:? :? :? thought this car was for sale ............... viewtopic.php?f=51&t=20075#p227806 .. :? :? :?
Re: Engine Swap by willowkevin on Sat Oct 04, 2008 8:15 am
its doable but i wouldn't! you'd have to swap the fuel tank sender , and what about the brake servo ? do they differ from petrol to diesel ? engine fits with a couple of mods to the gear box crossmember but you need the isuzu gearbox and a rear prop from a 2.3td is needed (i think!) as ste says , stick with the 2.4 !! sure wold save backche ! :D
frontera 2.8td hybrid
willowkevin
My car is mostly a Frontera
Vehicle Name: molliemobile
Modifications: hybrid isuzu 2.8td .5th year on still going strong ...
Re: Engine Swap by Tiddles on Sat Oct 04, 2008 12:32 pm
Tiddles
Nice gripy tyres :)
