Rear tailift window.
Rear tailift window. by Londonscruff on Wed Oct 01, 2008 6:48 pm
Does anybody know where I can see a diagram of the opening system of the window section of the tail gate?. Until yesterday i could unlock the back window with the switch near the steering column. It has now decided not work work which means that to open the back up the spare wheel has to be swung open then the tailgate has to be unlocked, all this is not easy for my wife to do./ Any suggestions would be of great help. :?
Londonscruff
Re: Rear tailift window. by bobbinsjob on Wed Oct 01, 2008 11:11 pm
hello mate, if you could update your pfofile with model, year etc you will have more chance of a correct answer. Someone will be along shortly to help
Re: Rear tailift window. by john (smifffy) on Thu Oct 02, 2008 4:08 pm
mahe sure you have the handbrake fully applied as there is a safety feature which stops window opening if handbrake is not fully on
