NEW OWNER NEEDS HELP!!!
NEW OWNER NEEDS HELP!!! by nambo on Fri Sep 19, 2008 4:23 pm
HI PEEPS, THE FRONTERA I JUST BOUGHT 2 WEEKS AGO WOULD NOT START, TOOK IT TO LOCAL GARAGE AND AFTER A LOT OF TRIAL AND ERROR, THE FAULT WAS TRACKED DOWN TO THE DIESEL FUEL PUMP NOT WORKING!!!!-HAVE BEEN QUOTED £2000 + VAT FOR A RECON ONE, BUT AFTER PAYING £1200 FOR THE WAGON I CAN NOT JUSTIFY THIS COST TO FIX IT--SO I AM LOOKING FOR ANY IDEAS OR ADVICE :( :( :(
nambo
Registration Year: 1999/S
Re: NEW OWNER NEEDS HELP!!! by Rifleman on Fri Sep 19, 2008 5:38 pm
Hi mate, someone will come up with a solution for you, probably Lawrence, Smiffy or Bernie.
But I will slip a wee word to you first before they do, don't type in capitals as it is seen as shouting bud.
Good luck with the pump.
Re: NEW OWNER NEEDS HELP!!! by bobbinsjob on Fri Sep 19, 2008 6:09 pm
Hello mate, if it is the fuel pump then I'm afraid it is very expensive but not £2000 for a recon. I have seen them for about £600 for a recon then the fitting.
You could get a new one fitted for less than £2000 :shock: :shock:
Re: NEW OWNER NEEDS HELP!!! by nambo on Fri Sep 19, 2008 6:14 pm
thanks, advice taken on board!!
nambo
Re: NEW OWNER NEEDS HELP!!! by bobbinsjob on Fri Sep 19, 2008 6:25 pm
keep an eye on this thread, A friend may have some useful info later
viewtopic.php?f=18&t=20096
Re: NEW OWNER NEEDS HELP!!! by Drift on Fri Sep 19, 2008 6:37 pm
If you can get it to a diesel specialist they my recon and fit your old unit a lot cheaper, its still not a cheap fix but I reckon at the very most £1000, you could be lucky and get it done for a little less.
Try calling these guys for a quote or an email, they are very helpful and will give give you an idea of the price :wink:
http://www.dieselbob.co.uk/injectionpumps.shtml
Re: NEW OWNER NEEDS HELP!!! by Trugga on Fri Sep 19, 2008 8:52 pm
I concur.
Give diesel bob a call or see if you can find a local diesel specialist. There is also the option of trying to find one on a scrapper.
I have a new pump that will be fitted to my 2.8 and will replace the old (still working) pump, but it is going to possibly be 6 months before that happens. I have located a local diesel specialist (In Redditch, Worcestershire) that can take a Trooper pump and swap over the Vauxhall immobiliser and fit and tune it - that's going to cost a couple of hundred £.
Re: NEW OWNER NEEDS HELP!!! by nambo on Fri Sep 19, 2008 9:07 pm
Thanks guys for your help, will try and get my thoughts together and decide what to do :drink:
nambo
Re: NEW OWNER NEEDS HELP!!! by Drift on Fri Sep 19, 2008 9:10 pm
They are a good engine and car, the only problem is the pump, but once sorted it will be uprated and should never give any problems again.
One word though in the DTI never run out of fuel, the pumps hate that :wink:
Re: NEW OWNER NEEDS HELP!!! by Road Hog on Fri Sep 19, 2008 9:13 pm
You say trial & error :? did the garage read the fault codes ?
Re: NEW OWNER NEEDS HELP!!! by nambo on Fri Sep 19, 2008 9:25 pm
hi A friend, yea fault codes said a faulty crank shaft sensor and this was replaced but made no difference?? just wondering if it could be an immoberliser problem as mechanics said that when the engine was turning fuel was reaching where it should--sorry i cant be more precise but i know nowt about mechanics.
nambo
Re: NEW OWNER NEEDS HELP!!! by Drift on Fri Sep 19, 2008 9:29 pm
From that I would say its not the pump :D
Re: NEW OWNER NEEDS HELP!!! by Road Hog on Fri Sep 19, 2008 9:46 pm
Agree with Drift on the pump,the fault could be anywhere on the sensor circuit,what we need here is a Nitromotor.
Paul will probably be our best bet on this,will point him in this direction when he comes online,in the meantime it might be handy to him if you could post the actual fault code number.Will also do some more looking myself.
Re: NEW OWNER NEEDS HELP!!! by nambo on Fri Sep 19, 2008 9:54 pm
will try and get the fault code number and post it-thanks everyone
nambo
Re: NEW OWNER NEEDS HELP!!! by nitromotor on Sat Sep 20, 2008 1:34 am
Pumps are rare to fail unless abused, so….
Check the fuel relay, and the fuel cut off solenoid. :wink:
One thing to note is your frontera is running an high pressure system, its not compatible with vegoil, vegoil will kill the pump , do you know the history?
Just have to mention that to rule that out, but await your fault codes.
Re: NEW OWNER NEEDS HELP!!! by nambo on Mon Sep 29, 2008 7:27 pm
Hi guys, well its proved to expensive/complicated to fix, so have had to sell my frontera!!!
Thanks to everyone who has made me welcome to this forum, and all those who have offered help and advice, I will tell the new owner of this club...I wonder if there is an Astra van owners forum????? :drink: :dance: :drink:
nambo
