smoke from the fuel rail
smoke from the fuel rail by kingfisher on Wed Sep 17, 2008 8:15 pm
when my fronty was off the road , i bought a volvo 850 to use till the fronty was repaired ,now i have a buyer for the volvo the problem is when i tried to start it there's smoke coming fron the fuel rail ,it was low on petrol so i put some in but it still wo,t start , it is turning over , and at one stage i thought i was gonna start , but no . any ideas guys :?
kingfisher
Vehicle Name: The money pit
Re: smoke from the fuel rail by Sir-Doris on Thu Sep 18, 2008 2:56 am
Sounds like something shorting out somewhere. Possibly a loose injector wire or similar if its in the area of the fuel rail
Re: smoke from the fuel rail by kingfisher on Thu Sep 18, 2008 11:58 pm
thanks mate will check it out tommorrow
kingfisher
Re: smoke from the fuel rail by Sir-Doris on Fri Sep 19, 2008 12:10 am
Any smells to go with the smoke? Different smoke has different smells ya see.
Re: smoke from the fuel rail by kingfisher on Fri Sep 19, 2008 12:18 am
well its got a slight petrol smell to it , not a strong smell , and the smoke is a grey colour :?:
kingfisher
Re: smoke from the fuel rail by Sir-Doris on Fri Sep 19, 2008 12:20 am
Not plastic or an electrical smell then?
Re: smoke from the fuel rail by kingfisher on Fri Sep 19, 2008 12:27 am
no mate , its really got me foxed , i don,t want to spend any cash on it as i advertised it as spares or repair , on fleabay . the guys coming for it tommorrow , but in the ad i didn,t say it was running , still if the guy does'nt want it i will just have to put it down to expereince and readvertise it , i would like to know what it is though just in case the fronty has the same problem
kingfisher
Re: smoke from the fuel rail by Road Hog on Fri Sep 19, 2008 12:36 am
Could it be a cloud of vapourised petrol from a cracked fuel line/fitting ??
Re: smoke from the fuel rail by kingfisher on Fri Sep 19, 2008 12:41 am
when i looked earlier there was a plastic pipe that was sitting on the engine just below the injectors i thought it was just a breather pipe , as the one end didn't seem to go anywhere , i wonder if thats it
kingfisher
Re: smoke from the fuel rail by Road Hog on Fri Sep 19, 2008 12:57 am
It mat well be the answer to your problem,as if fuel is escaping the engine will be running lean,for starting from cold the engine needs a fuel rich mixture.Got to be worth a look I reckon if only for elimination purposes.
Re: smoke from the fuel rail by kingfisher on Sat Sep 20, 2008 12:52 am
yep thats what was doing it , the bloke who bought it is a volvo spares / complete cars specialists , when he came to pick it up ,i showed him the pipe , and apparently it is a common fault with volvos , because the pipe sits on the engine it gets hot and as time goes by the pipe becomes brittle , thanks sir doris and A friend
kingfisher
Re: smoke from the fuel rail by Drift on Sat Sep 20, 2008 1:43 am
Well done guys :well done:
