Frontera Technical Support • View topic - 4x4 gear stick pops out into neutral
4x4 gear stick pops out into neutral by 2old0_0 on Sun Sep 07, 2008 9:37 pm
Hello I have just bought my frontera 2.2 limited four days ago never owned one before and was wondering if you could help me with the four wheel drive gear box I don't know if I'm doing it properly but when I changed into 4 wheel drive by pressing a button on the dashboard while the vehicle is moving at about 50 miles per hour on the road it drives in 4 wheel drive for a little while and then the 4x4 gear stick pops out into neutral and I can't push it back till I stop. Am I doing something wrong or do I have a problem with my gear box thanks Nigel.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...'Wow! What a ride!
2old0_0
Re: 4x4 gear stick pops out into neutral by Sir-Doris on Sun Sep 07, 2008 10:17 pm
Hi, You shouldnt use 4wd on a hard surface (concrete, tarmac etc) as something will break. It will 'pop out' of 4wd as a safety measure.
4wd in fronteras should only ever used on surface where the wheels are allowed to slip otherwise wind-up will occur.
See here for a description of Wind-Up and 4wd systems in general: http://www.fronteraowners.co.uk/info/4wd.htm
And here: www.fronteraowners.co.uk/info/using4wdfaq.htm
Re: 4x4 gear stick pops out into neutral by 2old0_0 on Sun Sep 07, 2008 10:37 pm
Thanks for your reply your advice has been very helpful :oops:
2old0_0
Re: 4x4 gear stick pops out into neutral by Road Hog on Mon Sep 08, 2008 12:08 am
Use of 4wd should be documented on the reverse side of the drivers sun visor in B series (which yours is).
Is your car petrol or diesel ??
Re: 4x4 gear stick pops out into neutral by nitromotor on Mon Sep 08, 2008 12:21 am
Petrol, im thinking owing to the LPG ref :wink:
Re: 4x4 gear stick pops out into neutral by weave67 on Mon Sep 08, 2008 5:44 am
ime just wondering why you would want to put your car in 4 wheel drive at 50 mph :D
Re: 4x4 gear stick pops out into neutral by alex on Mon Sep 08, 2008 7:08 am
Maybe to stop suddenly :lol:
Good job it aint an A or it would be a trip back up the road to pick up the gearbox. :oops:
Re: 4x4 gear stick pops out into neutral by Road Hog on Mon Sep 08, 2008 8:38 am
Re: 4x4 gear stick pops out into neutral by Road Hog on Mon Sep 08, 2008 8:42 am
Re: 4x4 gear stick pops out into neutral by 2old0_0 on Mon Sep 08, 2008 10:21 am
Thanks everyone for your replies as you can probably work it out I don't know the first thing about off-road or at least not in a 4 wheel drive vehicle. As for why was I putting it in 4 wheel drive at 50 mph well firstly I knew nothing about wind up and the purpose of doing this was just to find out if the car was making any usual noises having only got it for days before. One of my mates tells me that when the car is accelerating he can hear a noise rather like a stack of cards been flicked through this is just under hard acceleration the vehicle is a petrol version and has not been modified in any way does anyone know what that might be? The vehicles done 41,000 miles and has a full service history so I'm hoping that this is just normal and nothing to worry about. Cheers. :?
2old0_0
Re: 4x4 gear stick pops out into neutral by Rifleman on Mon Sep 08, 2008 1:40 pm
Silver Ghost
Registration Year: 1999/S
Re: 4x4 gear stick pops out into neutral by 2old0_0 on Mon Sep 08, 2008 4:01 pm
2old0_0
Re: 4x4 gear stick pops out into neutral by 2old0_0 on Mon Sep 08, 2008 4:11 pm
2old0_0
Re: 4x4 gear stick pops out into neutral by Road Hog on Mon Sep 08, 2008 4:17 pm
Hi bud,if you want to modify your profile your model option is 2.2i 5dr. :wink:
i = petrol injection
Dti = Diesel
Re: 4x4 gear stick pops out into neutral by 2old0_0 on Mon Sep 08, 2008 6:07 pm
Cheers gipsy I will do that.
2old0_0
Re: 4x4 gear stick pops out into neutral by weave67 on Mon Sep 08, 2008 7:04 pm
dont worry mate when i first got mine i didnot have a clue about 4 wheel drive either,ime supprised i didnt blow my front axle to peices the amount of times i drove in four wheel drive on tarmac :roll: my advice is to make yourself a coffee and sit down relax you will find all the info you need from the bods on here :wink:
